Both sides previous revision
Previous revision
Next revision
Previous revision
Next revision
Both sides next revision
hepsim:usage_detectors [2017/02/13 19:10] hepsim17 [Full (Geant4) simulations] |
hepsim:usage_detectors [2017/03/16 00:30] hepsim17 |
Full simulations use SLIC software. | Full simulations use the SLIC software. The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|here]]. |
The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|here]]. | |
Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as |
| rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull014 | Same as SiFFC-v7, but relaxed hit cuts for HCAL and ECAL | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.heprep|sifcch12.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull014| find=rfull014]] | {{:hepsim:sifcc7.png?200|SiFCC-v12}} | | | rfull014 | Same as SiFFC-v7, but relaxed hit cuts for HCAL and ECAL | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.heprep|sifcch12.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch12.gdml.gz|sifcch12.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull014| find=rfull014]] | {{:hepsim:sifcc7.png?200|SiFCC-v12}} | |
