Differences
Both sides previous revision Previous revision | |||
hepsim:usage_detectors [2017/04/03 03:04] hepsim17 |
hepsim:usage_detectors [2017/04/03 03:06] hepsim17 |
Line 9: | Line 9: | ||
All detectors can be found in [[http:// | All detectors can be found in [[http:// | ||
- | Data are reconstructed using the so-called reconstruction tags, which can have either " | + | Data are reconstructed using the so-called reconstruction tags, which can have either "**rfastXXX**" |
+ | You can find detectors that correspond to a given tag using [[http:// | ||
