Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hepsim:usage_download [2017/02/06 21:16]
127.0.0.1 external edit
hepsim:usage_download [2017/07/17 19:45]
hepsim17 [File validation]
Line 1: Line 1:
-[[hepsim:|<< back to HepSim manual]]+{{indexmenu_n>2}}
-======  How to download, view and find data ======+[[:|<< back to HepSim manual]]
 +======  HepSim data files ======
 ======  EVGEN events ====== ======  EVGEN events ======
Line 10: Line 12:
 The compact ProMC files optimized for web streaming, together with the http protocol optimized   The compact ProMC files optimized for web streaming, together with the http protocol optimized
 to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems. to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems.
 Simulated data after fast and full detector simulations are kept in ROOT and LCIO  formats.  Simulated data after fast and full detector simulations are kept in ROOT and LCIO  formats.
 ======  HepSim software toolkit ====== ======  HepSim software toolkit ======
Line 54: Line 54:
 <code bash> <code bash>
-hs-view http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/higgs/pythia8/pythia8_higgs_1.promc +hs-view http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/mg5_httbar/tev14_mg5_Httbar_001.promc
 </code> </code>
-Here we looked at one file of the [[http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/qcd/pythia8/ | Pythia8 (QCD) sample]]. +Here we have looked at one file of the [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=141 | Pythia8 (QCD) sample]].
 Of course, one can look at the local file as well: Of course, one can look at the local file as well:
-hs-view pythia8_higgs_1.promc +wget http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/mg5_httbar/tev14_mg5_Httbar_001.promc
 +hs-view tev14_mg5_Httbar_001.promc
 </code> </code>
 after you downloaded it. after you downloaded it.
Line 69: Line 70:
 <hidden> <hidden>
-{{:community:promc_browser.png| ProMC browser}}+{{:hepsim:promc_browser.png| ProMC browser}}
 </hidden> </hidden>
 This works for full parton-shower simulations with detailed information on particles. This works for full parton-shower simulations with detailed information on particles.
-Unlike the usual parton shower Monte Carlo, this  browser has a detailed information on event weights, PDF uncertainties and scale uncertainties (in some cases). The browser can show 4-momenta of each event as well as the total cross sections (for NLO, you need to read all events to get an accurate cross section). Look at the [[asc:promc| ProMC file]] description.+Unlike the usual parton shower Monte Carlo, this  browser has a detailed information on event weights, PDF uncertainties and scale uncertainties (in some cases). The browser can show 4-momenta of each event as well as the total cross sections (for NLO, you need to read all events to get an accurate cross section). Look at the [[https://atlaswww.hep.anl.gov/asc/promc/| ProMC file]] description.
Line 82: Line 83:
-hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/higgs/pythia8/pythia8_higgs_1.promc+hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/mg5_httbar/tev14_mg5_Httbar_001.promc
 </code> </code>
Line 88: Line 89:
 <code> <code>
-File          = http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/higgs/pythia8/pythia8_higgs_1.promc +File          = http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/mg5_httbar/tev14_mg5_Httbar_001.promc
-ProMC version = 2 +ProMC version = 4
-Last modified = 2013-06-05 16:32:18 +Last modified = 2015-10-03 12:06:52
-Description   PYTHIA8;PhaseSpace:mHatMin = 20;PhaseSpace:pTHatMin = 20;ParticleDecays:limitTau0 = on; +Description   run_Httbar_14tev
-                ParticleDecays:tau0Max = 10;HiggsSM:all = on;+
 Events        = 10000 Events        = 10000
-Sigma    (pb) = 2.72474E1 ± 1.92589E-1 +Sigma    (pb) = 5.61176E-± 3.3035E-3
-Lumi   (pb-1) = 3.67007E2+Lumi   (pb-1) = 1.78197E4
 Varint units  = E:100000 L:1000 Varint units  = E:100000 L:1000
 Log file:     = logfile.txt Log file:     = logfile.txt
-The file was validated. Exit.+####  The file is healthy!  ####
 </code> </code>
 All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers. All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers.
-The "E:100000" means that all px,py,pz,e,mass were multiplied by 100000, while all distances (x,y,z,t) were multiplied by  1000.+The "E:100000" means that all px, py, pz, e, mass values are multiplied by 100000, while all distances (x,y,z,t) are multiplied by  1000.
 See the [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC archive format]]. See the [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC archive format]].
Line 109: Line 109:
-hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/higgs/pythia8/pythia8_higgs_1.promc 100+hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/mg5_httbar/tev14_mg5_Httbar_001.promc 100
 </code> </code>
 ====== List available data files ====== ====== List available data files ======
Line 129: Line 127:
-hs-ls tev100_higgs_ttbar_mg5+hs-ls tev100pp_higgs_ttbar_mg5
 </code> </code>
Line 135: Line 133:
-hs-ls tev100_higgs_ttbar_mg5 simple+hs-ls tev100pp_higgs_ttbar_mg5 simple
 </code> </code>
 The string "simple" removes the decorations. If you want a list with full URL and without decorations, use: The string "simple" removes the decorations. If you want a list with full URL and without decorations, use:
-hs-ls tev100_higgs_ttbar_mg5 simple-url+hs-ls tev100pp_higgs_ttbar_mg5 simple-url
 </code> </code>
Line 211: Line 209:
 If you are interested in a specific reconstruction tag, use "%" to separate the search string and the tag name. If you are interested in a specific reconstruction tag, use "%" to separate the search string and the tag name.
 Example: Example:
 hs-find pythia%rfast001 hs-find pythia%rfast001
Line 224: Line 223:
 </code> </code>
 where [name] is either the name of the dataset, or the URL of Info page [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]], or a direct URL pointing to the locations of ProMC files. where [name] is either the name of the dataset, or the URL of Info page [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]], or a direct URL pointing to the locations of ProMC files.
-This example downloads dataset "tev100_higgs_ttbar_mg5" to the directory "data":+This example downloads dataset "tev100pp_higgs_ttbar_mg5" to the directory "data":
-hs-get tev100_higgs_ttbar_mg5 data+hs-get tev100pp_higgs_ttbar_mg5 data
 </code> </code>
 You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files. You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files.
Line 238: Line 237:
 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data
 </code> </code>
-All these examples will download all files from the "tev100_higgs_ttbar_mg5" event sample. +All these examples will download all files from the "tev100pp_higgs_ttbar_mg5" event sample.
 <note important>If you see that the download is slow, use an alternative URL from the mirror list which is given for each dataset. <note important>If you see that the download is slow, use an alternative URL from the mirror list which is given for each dataset.
Line 252: Line 251:
 Instead of [Download URL], one can use the URL of the info page, or the name of the dataset. Instead of [Download URL], one can use the URL of the info page, or the name of the dataset.
-Here are 2 identical examples to download 5 files using single (1) thread and the ouput directory "data":+Here are 2 identical examples to download 5 files using single (1) thread and the output directory "data":
 Using the URL of the info page: Using the URL of the info page:
Line 260: Line 259:
 or, when using the dataset name given on the info page: or, when using the dataset name given on the info page:
-hs-get tev100_higgs_ttbar_mg5  data 1 5+hs-get tev100pp_higgs_ttbar_mg5  data 1 5
 </code> </code>
 You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts, You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts,
-the names are usually have the substring "pt", followed by the pT cuts. In this case, one can download such files as:+the names are usually have the sub-string "pt", followed by the pT cuts. In this case, one can download such files as:
-hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_+hs-get tev13pp_higgs_pythia8_ptbins data 2 5 pt100_
 </code> </code>
 The last argument shows that all the downloaded files should have the string "pt100_" in their names (in this case, it tells that the  The last argument shows that all the downloaded files should have the string "pt100_" in their names (in this case, it tells that the
Line 275: Line 274:
-[URL] [OUTPUT_DIR] [Nr of threads (optional)] [Nr of files (optional)] [pattern (optional)].+hs-get [URL] [OUTPUT_DIR] [Nr of threads (optional)] [Nr of files (optional)] [pattern (optional)].
 </code> </code>
 where [URL] is either info URL, [Download URL], or the dataset name. where [URL] is either info URL, [Download URL], or the dataset name.
Line 288: Line 287:
 Reconstructed files are stored inside the directory "rfastNNN" (fast simulation) or "rfullNNN" (full simulation), Reconstructed files are stored inside the directory "rfastNNN" (fast simulation) or "rfullNNN" (full simulation),
 where "NNN" is the version number. For example, where "NNN" is the version number. For example,
-[[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100_ttbar_mg5]] sample includes the link "rfast001" (Delphes+[[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100pp_ttbar_mg5]] sample includes the link "rfast001" (Delphes
 fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax: fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax:
-hs-ls  tev100_ttbar_mg5%rfast001      # list reco files with the tag "rfast001" +hs-ls  tev100pp_ttbar_mg5%rfast001      # list reco files with the tag "rfast001"
-hs-get tev100_ttbar_mg5%rfast001 data # download to the "data" directory+hs-get tev100pp_ttbar_mg5%rfast001 data # download to the "data" directory
 </code> </code>
-The symbol "%" separates the sample name (tev100_ttbar_mg5) from the reconstruction tag (rfast001).+The symbol "%" separates the sample name (tev100pp_ttbar_mg5) from the reconstruction tag (rfast001).
 If you want to download 10 files in 3 threads, use this: If you want to download 10 files in 3 threads, use this:
 <code> <code>
-hs-get  tev100_ttbar_mg5%rfast001 data 3 10+hs-get  tev100pp_ttbar_mg5%rfast001 data 3 10
 </code> </code>
Line 318: Line 317:
- Send comments to:  --- //[[[email protected]|Sergei Chekanov (ANL)]] 2014/02/08 10:26//+Written by  //[[[email protected]|Sergei Chekanov (ANL)]] 2016/02/08 10:26//
