Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
hepsim:usage_download [2017/02/07 22:00]
hepsim17 [Downloading files after detector simulation]
hepsim:usage_download [2017/06/09 22:00]
hepsim17
Line 3: Line 3:
 [[:|<< back to HepSim manual]] [[:|<< back to HepSim manual]]
-======  Download, view and find data ======+======  HepSim data files ======
 ======  EVGEN events ====== ======  EVGEN events ======
Line 12: Line 12:
 The compact ProMC files optimized for web streaming, together with the http protocol optimized   The compact ProMC files optimized for web streaming, together with the http protocol optimized
 to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems. to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems.
 Simulated data after fast and full detector simulations are kept in ROOT and LCIO  formats.  Simulated data after fast and full detector simulations are kept in ROOT and LCIO  formats.
 ======  HepSim software toolkit ====== ======  HepSim software toolkit ======
Line 104: Line 102:
 All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers. All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers.
-The "E:100000" means that all px,py,pz,e,mass were multiplied by 100000, while all distances (x,y,z,t) were multiplied by  1000.+The "E:100000" means that all px, py, pz, e, mass values are multiplied by 100000, while all distances (x,y,z,t) are multiplied by  1000.
 See the [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC archive format]]. See the [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC archive format]].
Line 111: Line 109:
 <code bash> <code bash>
-hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/higgs/pythia8/pythia8_higgs_1.promc 100+hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc 100
 </code> </code>
Line 131: Line 129:
-hs-ls tev100_higgs_ttbar_mg5+hs-ls tev100pp_higgs_ttbar_mg5
 </code> </code>
Line 137: Line 135:
-hs-ls tev100_higgs_ttbar_mg5 simple+hs-ls tev100pp_higgs_ttbar_mg5 simple
 </code> </code>
 The string "simple" removes the decorations. If you want a list with full URL and without decorations, use: The string "simple" removes the decorations. If you want a list with full URL and without decorations, use:
-hs-ls tev100_higgs_ttbar_mg5 simple-url+hs-ls tev100pp_higgs_ttbar_mg5 simple-url
 </code> </code>
Line 213: Line 211:
 If you are interested in a specific reconstruction tag, use "%" to separate the search string and the tag name. If you are interested in a specific reconstruction tag, use "%" to separate the search string and the tag name.
 Example: Example:
 hs-find pythia%rfast001 hs-find pythia%rfast001
Line 226: Line 225:
 </code> </code>
 where [name] is either the name of the dataset, or the URL of Info page [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]], or a direct URL pointing to the locations of ProMC files. where [name] is either the name of the dataset, or the URL of Info page [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]], or a direct URL pointing to the locations of ProMC files.
-This example downloads dataset "tev100_higgs_ttbar_mg5" to the directory "data":+This example downloads dataset "tev100pp_higgs_ttbar_mg5" to the directory "data":
-hs-get tev100_higgs_ttbar_mg5 data+hs-get tev100pp_higgs_ttbar_mg5 data
 </code> </code>
 You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files. You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files.
Line 240: Line 239:
 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data
 </code> </code>
-All these examples will download all files from the "tev100_higgs_ttbar_mg5" event sample. +All these examples will download all files from the "tev100pp_higgs_ttbar_mg5" event sample.
 <note important>If you see that the download is slow, use an alternative URL from the mirror list which is given for each dataset. <note important>If you see that the download is slow, use an alternative URL from the mirror list which is given for each dataset.
Line 254: Line 253:
 Instead of [Download URL], one can use the URL of the info page, or the name of the dataset. Instead of [Download URL], one can use the URL of the info page, or the name of the dataset.
-Here are 2 identical examples to download 5 files using single (1) thread and the ouput directory "data":+Here are 2 identical examples to download 5 files using single (1) thread and the output directory "data":
 Using the URL of the info page: Using the URL of the info page:
Line 262: Line 261:
 or, when using the dataset name given on the info page: or, when using the dataset name given on the info page:
-hs-get tev100_higgs_ttbar_mg5  data 1 5+hs-get tev100pp_higgs_ttbar_mg5  data 1 5
 </code> </code>
 You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts, You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts,
-the names are usually have the substring "pt", followed by the pT cuts. In this case, one can download such files as:+the names are usually have the sub-string "pt", followed by the pT cuts. In this case, one can download such files as:
-hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_+hs-get tev13pp_higgs_pythia8_ptbins data 2 5 pt100_
 </code> </code>
 The last argument shows that all the downloaded files should have the string "pt100_" in their names (in this case, it tells that the  The last argument shows that all the downloaded files should have the string "pt100_" in their names (in this case, it tells that the
Line 277: Line 276:
-[URL] [OUTPUT_DIR] [Nr of threads (optional)] [Nr of files (optional)] [pattern (optional)].+hs-get [URL] [OUTPUT_DIR] [Nr of threads (optional)] [Nr of files (optional)] [pattern (optional)].
 </code> </code>
 where [URL] is either info URL, [Download URL], or the dataset name. where [URL] is either info URL, [Download URL], or the dataset name.
Line 290: Line 289:
 Reconstructed files are stored inside the directory "rfastNNN" (fast simulation) or "rfullNNN" (full simulation), Reconstructed files are stored inside the directory "rfastNNN" (fast simulation) or "rfullNNN" (full simulation),
 where "NNN" is the version number. For example, where "NNN" is the version number. For example,
-[[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100_ttbar_mg5]] sample includes the link "rfast001" (Delphes+[[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100pp_ttbar_mg5]] sample includes the link "rfast001" (Delphes
 fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax: fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax:
-hs-ls  tev100_ttbar_mg5%rfast001      # list reco files with the tag "rfast001" +hs-ls  tev100pp_ttbar_mg5%rfast001      # list reco files with the tag "rfast001"
-hs-get tev100_ttbar_mg5%rfast001 data # download to the "data" directory+hs-get tev100pp_ttbar_mg5%rfast001 data # download to the "data" directory
 </code> </code>
-The symbol "%" separates the sample name (tev100_ttbar_mg5) from the reconstruction tag (rfast001).+The symbol "%" separates the sample name (tev100pp_ttbar_mg5) from the reconstruction tag (rfast001).
 If you want to download 10 files in 3 threads, use this: If you want to download 10 files in 3 threads, use this:
 <code> <code>
-hs-get  tev100_ttbar_mg5%rfast001 data 3 10+hs-get  tev100pp_ttbar_mg5%rfast001 data 3 10
 </code> </code>
