Differences
hepsim:usage_download [2017/03/08 16:47] hepsim17 |
hepsim:usage_download [2017/07/17 19:44] hepsim17 [Event record browser] |
Line 3: | Line 3: | ||
Line 54: | Line 54: | ||
- | hs-view http:// | + | hs-view http:// |
- | Here we looked at one file of the [[http://mc.hep.anl.gov/asc/hepsim/events/ | + | Here we have looked at one file of the [[http://atlaswww.hep.anl.gov/ |
Of course, one can look at the local file as well: | Of course, one can look at the local file as well: | ||
- | hs-view | + | wget http:// |
+ | hs-view | ||
after you downloaded it. | after you downloaded it. | ||
Line 129: | Line 130: | ||
- | hs-ls tev100_higgs_ttbar_mg5 | + | hs-ls tev100pp_higgs_ttbar_mg5 |
Line 135: | Line 136: | ||
The string " | The string " | ||
Line 225: | Line 226: | ||
where [name] is either the name of the dataset, or the URL of Info page [[http:// | where [name] is either the name of the dataset, or the URL of Info page [[http:// | ||
- | This example downloads dataset "tev100_higgs_ttbar_mg5" to the directory " | + | This example downloads dataset "tev100pp_higgs_ttbar_mg5" to the directory " |
- | hs-get | + | hs-get |
You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files. | You will be prompted to use certain mirror (if there are alternative mirrors). Select the mirror and start downloading the files. | ||
Line 239: | Line 240: | ||
hs-get http:// | hs-get http:// | ||
- | All these examples will download all files from the "tev100_higgs_ttbar_mg5" event sample. | + | All these examples will download all files from the "tev100pp_higgs_ttbar_mg5" event sample. |
<note important> | <note important> | ||
Line 253: | Line 254: | ||
Instead of [Download URL], one can use the URL of the info page, or the name of the dataset. | Instead of [Download URL], one can use the URL of the info page, or the name of the dataset. | ||
- | Here are 2 identical examples to download 5 files using single (1) thread and the ouput directory " | + | Here are 2 identical examples to download 5 files using single (1) thread and the output |
Using the URL of the info page: | Using the URL of the info page: | ||
Line 261: | Line 262: | ||
or, when using the dataset name given on the info page: | or, when using the dataset name given on the info page: | ||
You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts, | You can also download files that have certain pattern in the names. If a directory contains files generated with different pt cuts, | ||
- | the names are usually have the substring | + | the names are usually have the sub-string |
The last argument shows that all the downloaded files should have the string " | The last argument shows that all the downloaded files should have the string " | ||
Line 289: | Line 290: | ||
Reconstructed files are stored inside the directory " | Reconstructed files are stored inside the directory " | ||
where " | where " | ||
- | [[http:// | + | [[http:// |
fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | ||
- | hs-ls | + | hs-ls |
- | The symbol " | + | The symbol " |
If you want to download 10 files in 3 threads, use this: | If you want to download 10 files in 3 threads, use this: | ||
