Differences
hepsim:usage_full [2017/04/03 01:00] hepsim17 [Using C++/ROOT with LCIO] |
hepsim:usage_full [2017/04/26 03:35] hepsim17 [Using C++/ROOT with LCIO] |
Line 106: | Line 106: | ||
====== Using C++/ROOT with LCIO ====== | ====== Using C++/ROOT with LCIO ====== | ||
- | If you need to read LCIO files in C++ code with ROOT/ | + | If you need to read LCIO files in C++ code with ROOT/ |
- | wget http://atlaswww.hep.anl.gov/hepsim/soft/ | + | git clone https://github.com/chekanov/HepSim |
- | cd lcio-cpp; make | + | cd HepSim/ |
- | It will compile " | + | Look at README file to see how to install the " |
- | Your program to read SLCIO files can look as this: | + | Generally, you program to read SLCIO files can look as this: |
<hidden Click here to show the code example> | <hidden Click here to show the code example> | ||
Line 128: | Line 128: | ||
cout << " | cout << " | ||
// print stored EVGEN parameters | // print stored EVGEN parameters | ||
+ | const LCParameters& | ||
int nFloatParameters = params.getFloatKeys( floatKeys ).size() ; | int nFloatParameters = params.getFloatKeys( floatKeys ).size() ; |
