Differences
hepsim:usage_full [2017/04/26 03:35] hepsim17 [Using C++/ROOT with LCIO] |
hepsim:usage_full [2020/05/22 02:50] hepsim17 |
Line 3: | Line 3: | ||
Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | ||
Line 10: | Line 10: | ||
The files with full simulations are located under the " | The files with full simulations are located under the " | ||
- | Here how you can find all samples that have " | + | Here how you can find all samples that have " |
The description of the detector tags is given in [[: | The description of the detector tags is given in [[: | ||
If you need to find all files | If you need to find all files | ||
Line 26: | Line 26: | ||
- | The [[http:// | + | The [[https:// |
- | Each " | + | Each " |
The physics performance studies based on full simulation files from HepSim | The physics performance studies based on full simulation files from HepSim | ||
Line 43: | Line 43: | ||
- | wget http:// | + | wget https:// |
tar -zvxf jas4pp.tgz | tar -zvxf jas4pp.tgz | ||
cd jas4pp | cd jas4pp |
