Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
hepsim:usage_truth [2017/02/07 21:58]
hepsim17
hepsim:usage_truth [2017/09/21 14:03]
hepsim17 [Converting to LCIO]
Line 18: Line 18:
 As before, make sure that [[http://java.com/en/download/index.jsp|Java 7]] and above is installed (check it as "java -version"). As before, make sure that [[http://java.com/en/download/index.jsp|Java 7]] and above is installed (check it as "java -version").
-===== Method I. Running in a batch mode without downloaded ProMC files =====+======  Streaming over the network  ======
 You can run validation scripts in a batch mode as: You can run validation scripts in a batch mode as:
Line 60: Line 60:
 If you want to see a pop-up canvas with the output histogram on your screen, change the line "c1.visible(False)" to "c1.visible()" and comment out  "sys.exit(0)" at the very end of the "ttbar_mg5.py" macro. You can change the output format from "SVG" to "PDF", "EPS" or "PNG". Look at the [[http://jwork.org/dmelt/api/doc.php/jhplot/package-summary | Java API]]. If you want to see a pop-up canvas with the output histogram on your screen, change the line "c1.visible(False)" to "c1.visible()" and comment out  "sys.exit(0)" at the very end of the "ttbar_mg5.py" macro. You can change the output format from "SVG" to "PDF", "EPS" or "PNG". Look at the [[http://jwork.org/dmelt/api/doc.php/jhplot/package-summary | Java API]].
-===== Method IIRunning in batch mode after downloading ProMC files ====+
 +====== Using Java WebStart ======
 +Many "Info" pages of HepSim have Jython (Python) scripts for validation and analysisOne can run such scripts from the web browsers using the Java Web Start technology. Click the "Launch" button. You will see an editor. Then click the "Run" button to process events.
 +To use Java Web Start, you should configure Java permissions: For Linux/Mac, run "ControlPanel", go to the "Security" tab and add "http://atlaswww.hep.anl.gov" to the exception list. For Windows, find "Java Control Panel" and do the same. Read [[https://www.java.com/en/download/help/java_blocked.xml|Why are Java applications blocked by your security settings]]. In addition, if you are Mac user, you should allow execution of programs outside Mac App Store.
 +======  Downloaded ProMC files ======
 The above approach depends on network availability at the time when you do the analysis. The above approach depends on network availability at the time when you do the analysis.
Line 82: Line 91:
 Similarly,  you can use  [[http://atlaswww.hep.anl.gov/asc/jas4pp | Jas4pp]]. Similarly,  you can use  [[http://atlaswww.hep.anl.gov/asc/jas4pp | Jas4pp]].
-===== Method III. Running in a GUI mode  ====+
 +======  Running in a GUI mode ======
 You can perform short validation analysis using an editor as: You can perform short validation analysis using an editor as:
Line 107: Line 117:
 It will open the Python script for editing. Next, run this  script by clicking the image of green running man on the status bar (or press [F8]). It will open the Python script for editing. Next, run this  script by clicking the image of green running man on the status bar (or press [F8]).
-===== Method IV. Running in a GUI mode using URL dialog  ====+====== Using GUI URL dialogue ======
- +If you use DMelt, you can run this code using a more conventional editor:
-If you use DMelt, you can run this code using +
-a more conventional editor:+
 <code bash> <code bash>
Line 217: Line 224:
 </code> </code>
- +Click the event number ('left pannel"and then look at "Event info" It shows the integer values (idata) that encode the PDF uncertainties, while the float array ("fdata") shows other information. The first element in the float array is the weight of the event. The particle information is shown as usual (but without mother ID etc.).
-On the left panel, click on the event and then look at "Event info" It shows the integer values (idata) that encode the PDF uncertainties, while the float array ("fdata") shows other information. The first element in the float array is the weight of the event. The particle information is shown as usual (but without mother ID etc.). +
 <hidden> <hidden>
Line 238: Line 244:
 NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as:
-{{:screenshot-26.png?300}}+{{:hepsim:screenshot-26.png?300}}
 You can calculate differential cross sections using online files using this example: You can calculate differential cross sections using online files using this example:
Line 250: Line 256:
 </code> </code>
-This example runs "higgsjet_gamgam_mcfm.py" code using online files and creates  a Higgs differential cross section with PDF uncertainties. +This example runs "higgsjet_gamgam_mcfm.py" code using online files and creates  a Higgs differential cross section with PDF uncertainties. We use DMelt to do the calculations (after updating one jar file). You can also use ROOT/C++ to do the same.
-We use DMelt to do the calculations (after updating one jar file). You can also use ROOT/C++ to do the same.+
Line 333: Line 338:
 ====== Converting to LCIO ====== ====== Converting to LCIO ======
-ProMC files can be converted to LCIO files for full detector simulations.  This is an example of such conversion (it requires Java installed):+ProMC files can be converted to LCIO or STDHEP
 +files for full detector simulations.  See [[hepsim:dev_full|LCIO/STDHEP section]] for detail.
 +Note that the converters are included inside the ProMC package (see the directory "examples"). Here is an example:
 +<hidden>
 wget http://atlaswww.hep.anl.gov/asc/promc/download/current.php -O ProMC.tgz wget http://atlaswww.hep.anl.gov/asc/promc/download/current.php -O ProMC.tgz
Line 343: Line 352:
 java promc2lcio file.promc file.slcio java promc2lcio file.promc file.slcio
 </code> </code>
-The last commends creates  file.slcio with "MCparticle" container. +</hidden>
 +The last command creates  file.slcio with the "MCParticle" container.
Line 376: Line 387:
 <hidden> <hidden>
 <code python> <code python>
-!/usr/local/bin/python+#!/usr/local/bin/python
 # Convert jdat to the standard Python # Convert jdat to the standard Python
 # This can be used for converting data to pyROOT  # This can be used for converting data to pyROOT
