Differences
hepsim:usage_truth [2017/02/22 14:32] hepsim17 [Using Java WebStart] |
hepsim:usage_truth [2020/05/21 23:31] hepsim17 |
Line 18: | Line 18: | ||
As before, make sure that [[http:// | As before, make sure that [[http:// | ||
You can run validation scripts in a batch mode as: | You can run validation scripts in a batch mode as: | ||
Line 44: | Line 44: | ||
Look at the " | Look at the " | ||
- | Similarly, you can use a more complex [[http://jwork.org/dmelt/|DataMelt]]: | + | Similarly, you can use a more complex [[https://datamelt.org|DataMelt]]: |
- | wget -O dmelt.zip http:// | + | wget -O dmelt.zip http:// |
unzip dmelt.zip | unzip dmelt.zip | ||
Line 58: | Line 58: | ||
- | If you want to see a pop-up canvas with the output histogram on your screen, change the line " | + | If you want to see a pop-up canvas with the output histogram on your screen, change the line " |
Line 69: | Line 69: | ||
The above approach depends on network availability at the time when you do the analysis. | The above approach depends on network availability at the time when you do the analysis. | ||
Line 117: | Line 117: | ||
It will open the Python script for editing. Next, run this script by clicking the image of green running man on the status bar (or press [F8]). | It will open the Python script for editing. Next, run this script by clicking the image of green running man on the status bar (or press [F8]). | ||
If you use DMelt, you can run this code using a more conventional editor: | If you use DMelt, you can run this code using a more conventional editor: | ||
Line 240: | Line 240: | ||
- | Alternatively, | + | Alternatively, |
NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | ||
Line 256: | Line 256: | ||
- | This example runs " | + | This example runs " |
Line 338: | Line 338: | ||
====== Converting to LCIO ====== | ====== Converting to LCIO ====== | ||
- | ProMC files can be converted to LCIO files for full detector simulations. | + | ProMC files can be converted to LCIO or STDHEP |
+ | files for full detector simulations. | ||
+ | Note that the converters are included inside the ProMC package (see the directory " | ||
Line 348: | Line 352: | ||
java promc2lcio file.promc file.slcio | java promc2lcio file.promc file.slcio | ||
- | The last commends | + | </ |
+ | The last command | ||
Line 377: | Line 383: | ||
Many scripts of HepSim create SVG images and a cross platform | Many scripts of HepSim create SVG images and a cross platform | ||
- | [[http://jwork.org/dmelt/wikidoc/doku.php? | + | [[https://handwiki.org/wiki/DMelt:IO/8_Cross_Paltform_IO |
<code python> | <code python> | ||
# Convert jdat to the standard Python | # Convert jdat to the standard Python | ||
# This can be used for converting data to pyROOT | # This can be used for converting data to pyROOT |
