Differences
hepsim:usage_truth [2017/09/20 18:22] hepsim17 [XML output format] |
hepsim:usage_truth [2017/09/21 14:03] hepsim17 [Converting to LCIO] |
Line 338: | Line 338: | ||
====== Converting to LCIO ====== | ====== Converting to LCIO ====== | ||
- | ProMC files can be converted to LCIO files for full detector simulations. | + | ProMC files can be converted to LCIO or STDHEP |
+ | files for full detector simulations. | ||
+ | Note that the converters are included inside the ProMC package (see the directory " | ||
Line 348: | Line 352: | ||
java promc2lcio file.promc file.slcio | java promc2lcio file.promc file.slcio | ||
- | The last commends | + | </ |
+ | The last command | ||
