Differences
hepsim:usage_truth [2017/09/20 18:22] hepsim17 [XML output format] |
hepsim:usage_truth [2020/05/21 23:31] hepsim17 |
Line 44: | Line 44: | ||
Look at the " | Look at the " | ||
- | Similarly, you can use a more complex [[http://jwork.org/dmelt/|DataMelt]]: | + | Similarly, you can use a more complex [[https://datamelt.org|DataMelt]]: |
- | wget -O dmelt.zip http:// | + | wget -O dmelt.zip http:// |
unzip dmelt.zip | unzip dmelt.zip | ||
Line 58: | Line 58: | ||
- | If you want to see a pop-up canvas with the output histogram on your screen, change the line " | + | If you want to see a pop-up canvas with the output histogram on your screen, change the line " |
Line 240: | Line 240: | ||
- | Alternatively, | + | Alternatively, |
NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | ||
Line 256: | Line 256: | ||
- | This example runs " | + | This example runs " |
Line 338: | Line 338: | ||
====== Converting to LCIO ====== | ====== Converting to LCIO ====== | ||
- | ProMC files can be converted to LCIO files for full detector simulations. | + | ProMC files can be converted to LCIO or STDHEP |
+ | files for full detector simulations. | ||
+ | Note that the converters are included inside the ProMC package (see the directory " | ||
Line 348: | Line 352: | ||
java promc2lcio file.promc file.slcio | java promc2lcio file.promc file.slcio | ||
- | The last commends | + | </ |
+ | The last command | ||
Line 377: | Line 383: | ||
Many scripts of HepSim create SVG images and a cross platform | Many scripts of HepSim create SVG images and a cross platform | ||
- | [[http://jwork.org/dmelt/wikidoc/doku.php? | + | [[https://handwiki.org/wiki/DMelt:IO/8_Cross_Paltform_IO |
