Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hepsim:usage_truth [2017/09/21 14:02]
hepsim17 [Converting to LCIO]
hepsim:usage_truth [2020/05/21 23:31]
hepsim17
Line 44: Line 44:
 Look at the "example" directory of the Jas4pp installation. It has a several examples of how to process the ProMC files. Look at the "example" directory of the Jas4pp installation. It has a several examples of how to process the ProMC files.
-Similarly, you can use a more complex [[http://jwork.org/dmelt/|DataMelt]]:+Similarly, you can use a more complex [[https://datamelt.org|DataMelt]]:
 <code bash> <code bash>
-wget -O dmelt.zip http://jwork.org/dmelt/download/current.php                        # get DMelt+wget -O dmelt.zip http://jwork.org/dmelt/download/current.php                        # get DataMelt
 wget http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/macros/ttbar_mg5.py #  analysis script wget http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/macros/ttbar_mg5.py #  analysis script
 unzip dmelt.zip unzip dmelt.zip
Line 58: Line 58:
 </code> </code>
-If you want to see a pop-up canvas with the output histogram on your screen, change the line "c1.visible(False)" to "c1.visible()" and comment out  "sys.exit(0)" at the very end of the "ttbar_mg5.py" macro. You can change the output format from "SVG" to "PDF", "EPS" or "PNG". Look at the [[http://jwork.org/dmelt/api/doc.php/jhplot/package-summary | Java API]].+If you want to see a pop-up canvas with the output histogram on your screen, change the line "c1.visible(False)" to "c1.visible()" and comment out  "sys.exit(0)" at the very end of the "ttbar_mg5.py" macro. You can change the output format from "SVG" to "PDF", "EPS" or "PNG". Look at the [[http://datamelt.org/api/doc.php/jhplot/package-summary | Java API]].
Line 240: Line 240:
 </code> </code>
-Alternatively, open this script in the DMelt editor and press run (or [F8]).+Alternatively, open this script in the DataMelt editor and press run (or [F8]).
 NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as:
Line 256: Line 256:
 </code> </code>
-This example runs "higgsjet_gamgam_mcfm.py" code using online files and creates  a Higgs differential cross section with PDF uncertainties. We use DMelt to do the calculations (after updating one jar file). You can also use ROOT/C++ to do the same.+This example runs "higgsjet_gamgam_mcfm.py" code using online files and creates  a Higgs differential cross section with PDF uncertainties. We use DataMelt to do the calculations (after updating one jar file). You can also use ROOT/C++ to do the same.
Line 339: Line 339:
 ProMC files can be converted to LCIO or STDHEP  ProMC files can be converted to LCIO or STDHEP
-files for full detector simulations.  See [[hepsim:dev_full|LCIO section]] for detail. +files for full detector simulations.  See [[hepsim:dev_full|LCIO/STDHEP section]] for detail.
 Note that the converters are included inside the ProMC package (see the directory "examples"). Here is an example: Note that the converters are included inside the ProMC package (see the directory "examples"). Here is an example:
Line 383: Line 383:
 Many scripts of HepSim create SVG images and a cross platform  Many scripts of HepSim create SVG images and a cross platform
-[[http://jwork.org/dmelt/wikidoc/doku.php?id=man:io:crossplatform | JDAT data format based on HBook]]. In order to convert JDAT files into CPython or ROOT object, read the data using xml.dom. This is a conversion to the CPython:+[[https://handwiki.org/wiki/DMelt:IO/8_Cross_Paltform_IO | JDAT data format based on HBook]]. In order to convert JDAT files into CPython or ROOT object, read the data using xml.dom. This is a conversion to the CPython:
 <hidden> <hidden>
