Differences
hepsim:usage_view [2017/02/06 22:54] hepsim17 |
hepsim:usage_view [2019/08/07 19:33] hepsim17 [How to make such images] |
Line 5: | Line 5: | ||
====== Detector visualization ====== | ====== Detector visualization ====== | ||
- | Much of this topic has been discussed in the Section [[asc: | + | Much of this topic has been discussed in the Section [[hepsim: |
Line 17: | Line 17: | ||
Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | ||
- | {{:community: | + | {{: |
- | <fc # | + | |
Line 39: | Line 34: | ||
due to " | due to " | ||
A real pp (100 TeV) → Z' | A real pp (100 TeV) → Z' | ||
Line 66: | Line 61: | ||
This event has 25,000 hits in the HCAL+ECAL, and about 6,000 in the tracker. | This event has 25,000 hits in the HCAL+ECAL, and about 6,000 in the tracker. | ||
Line 75: | Line 70: | ||
- | Use [[asc: | + | Use [[hepsim: |
Line 83: | Line 78: | ||
- | jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | + | jaspp tev40mm_pythia6_zprime40tev_ww_0036_pandora.slcio |
Then press the small " | Then press the small " |
