Differences
hepsim:usage_view [2017/02/06 23:50] hepsim17 |
hepsim:usage_view [2019/08/07 19:33] hepsim17 [How to make such images] |
Line 24: | Line 24: | ||
- | <fc # | ||
Line 75: | Line 70: | ||
- | Use [[asc: | + | Use [[hepsim: |
Line 83: | Line 78: | ||
- | jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | + | jaspp tev40mm_pythia6_zprime40tev_ww_0036_pandora.slcio |
Then press the small " | Then press the small " |
