Differences
hepsim:usage_view [2017/02/06 23:50] hepsim17 |
hepsim:usage_view [2019/08/07 20:40] hepsim17 [How to make such images] |
Line 24: | Line 24: | ||
- | <fc # | ||
Line 75: | Line 70: | ||
- | Use [[asc: | + | Use [[hepsim: |
Line 82: | Line 77: | ||
cd jas4pp | cd jas4pp | ||
- | wget http:// | + | wget http:// |
- | jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | + | jaspp gev250_pythia6_zpole_bbar_0001_pandora.slcio |
Then press the small " | Then press the small " | ||
- | You will need a computer with at least 8 GB RAM. | + | You will need a computer with at least 8 GB RAM. This example is shown for e+e- events at 250 GeV. Similarly, use other files with the tag " |
You can download all reconstructed files as | You can download all reconstructed files as |
