Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
Last revision
Both sides next revision
hepsim:usage_view [2017/02/06 23:50] hepsim17 [How to make such images] |
hepsim:usage_view [2019/08/07 19:33] hepsim17 [How to make such images] |
{{:hepsim:z40_qqbar8.png?310|}} | {{:hepsim:z40_qqbar8.png?310|}} |
{{:hepsim:z40_qqbar9.png?300|}} | {{:hepsim:z40_qqbar9.png?300|}} |
<fc #FF0000>(click on the images to enlarge)</fc> | |
source ./setup.sh # takes 5 sec for first-time optimization | source ./setup.sh # takes 5 sec for first-time optimization |
wget http://mc.hep.anl.gov/asc/hepsim/events/mumu/40tev/mm40tev_pythia6_zprime_ww/rfull006/tev40mm_pythia6_zprime40tev_ww_0036_pandora.slcio | wget http://mc.hep.anl.gov/asc/hepsim/events/mumu/40tev/mm40tev_pythia6_zprime_ww/rfull006/tev40mm_pythia6_zprime40tev_ww_0036_pandora.slcio |
jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | jaspp tev40mm_pythia6_zprime40tev_ww_0036_pandora.slcio |
</code> | </code> |
Then press the small "run" (blue arrow) button on the toolbar. Then go to File → New → Wired 4 View. The you should wait for 5-10 before the image will appear. The first event from this file is what you see in the above images. | Then press the small "run" (blue arrow) button on the toolbar. Then go to File → New → Wired 4 View. The you should wait for 5-10 before the image will appear. The first event from this file is what you see in the above images. |
