Differences
hepsim:usage_view [2017/02/06 22:44] hepsim17 |
hepsim:usage_view [2019/08/07 20:40] (current) hepsim17 [How to make such images] |
Line 1: | Line 1: | ||
+ | {{indexmenu_n> | ||
- | Much of this topic has been discussed in the Section [[asc: | + | Much of this topic has been discussed in the Section [[hepsim: |
Line 15: | Line 17: | ||
Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | ||
- | {{:community: | + | {{: |
- | <fc # | + | |
Line 37: | Line 34: | ||
due to " | due to " | ||
A real pp (100 TeV) → Z' | A real pp (100 TeV) → Z' | ||
Line 64: | Line 61: | ||
This event has 25,000 hits in the HCAL+ECAL, and about 6,000 in the tracker. | This event has 25,000 hits in the HCAL+ECAL, and about 6,000 in the tracker. | ||
Line 73: | Line 70: | ||
- | Use [[asc: | + | Use [[hepsim: |
Line 80: | Line 77: | ||
cd jas4pp | cd jas4pp | ||
- | wget http:// | + | wget http:// |
- | jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | + | jaspp gev250_pythia6_zpole_bbar_0001_pandora.slcio |
Then press the small " | Then press the small " | ||
- | You will need a computer with at least 8 GB RAM. | + | You will need a computer with at least 8 GB RAM. This example is shown for e+e- events at 250 GeV. Similarly, use other files with the tag " |
You can download all reconstructed files as | You can download all reconstructed files as |
