Differences
start [2017/02/07 17:43] hepsim17 [How to cite] |
start [2022/03/17 20:18] hepsim17 [About HepSim] |
Line 1: | Line 1: | ||
- | ====== HepSim manual ====== | + | ====== HepSim manual ====== |
+ | ===== About HepSim ===== | ||
[[http:// | [[http:// | ||
The [[http:// | The [[http:// | ||
+ | It contains predictions | ||
+ | It also includes Monte Carlo events after fast (" | ||
+ | HepSim | ||
+ | for High-Luminosity LHC (HL-LHC), International Linear Collider (ILC), Very Large Hadron Collider (VLHC), Future Circular Collider (FCC-ee and FCC-hh), | ||
+ | Compact Linear Collider (CLIC), Circular Electron-Positron Collider (CEPC), Electron-Ion Collider (EIC) and other future particle colliders. | ||
+ | HepSim Monte Carlo samples are registered by the U.S. Department of Energy | ||
+ | Office of Scientific and Technical Information, | ||
+ | Each event sample is assigned a DOI (Digital Object Identifier) number as listed on the [[https:// | ||
+ | The assigned DOI numbers are also indicated on the HepSim information panel for datasets. | ||
+ | HepSim was designed following | ||
+ | the guidelines and principles of [[http:// | ||
+ | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
====== For HepSim users ====== | ====== For HepSim users ====== | ||
Line 12: | Line 31: | ||
* [[hepsim: | * [[hepsim: | ||
- | * [[hepsim: | + | * [[hepsim: |
Line 20: | Line 39: | ||
+ | <note tip>See also: {{: | ||
+ | ([[https:// | ||
- | Here are several links to extending this Wiki for particular detector-performance topics: | + | Here are several links for extending this Wiki for particular detector-performance topics: |
Line 37: | Line 59: | ||
- | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | + | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), read this: |
