Differences
start [2019/11/28 01:34] hepsim17 |
start [2022/03/17 20:18] hepsim17 [About HepSim] |
Line 1: | Line 1: | ||
- | ====== HepSim manual ====== | + | ====== HepSim manual ====== |
+ | ===== About HepSim ===== | ||
[[http:// | [[http:// | ||
Line 12: | Line 15: | ||
HepSim Monte Carlo samples are registered by the U.S. Department of Energy | HepSim Monte Carlo samples are registered by the U.S. Department of Energy | ||
- | Office of Scientific and Technical Information, | + | Office of Scientific and Technical Information, |
- | Each event sample is assigned a DOI (Digital Object Identifier) number as listed on the [https:// | + | Each event sample is assigned a DOI (Digital Object Identifier) number as listed on the [[https:// |
The assigned DOI numbers are also indicated on the HepSim information panel for datasets. | The assigned DOI numbers are also indicated on the HepSim information panel for datasets. | ||
HepSim was designed following | HepSim was designed following | ||
- | the guidelines and principles of [http:// | + | the guidelines and principles of [[http:// |
for unclassified and otherwise unrestricted scientific data in digital formats. | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
