User Tools
Site Tools
asc:asc_afs
How to install AFS
Instruction from Bob:
Here is how to setup afs:
Install the following packages (these are from the standard sl6 repo):
kmod-openafs
openafs
openafs-module-tools
openafs-krb5
openafs-client
You should make sure afs starts at boot and the only customization
required is, after installing the above and before starting the afs
service, do "echo cern.ch >/usr/vice/etc/ThisCell" as root.Here is how to setup afs:
kmod-openafs
openafs
openafs-krb5
openafs-client
To gain access to non-public files at cern you need to 1) get a kerberos
ticket with kinit and 2) issue the aklog command to translate it to an
afs token.
afs token.
Tested example:
yum install kmod-openafs openafs openafs-module-tools openafs-krb5 openafs-client
/sbin/service afs start
/sbin/chkconfig --add afs
# check
ls /afs/cern.ch/
asc/asc_afs.txt · Last modified: 2013/10/21 14:26 by asc
