asc:tutorials:eclipse
Table of Contents
Eclipse
This example touches only the basics. Some of our colleagues managed to integrate Eclipse with the ATLAS TDAQ environment: https://twiki.cern.ch/twiki/bin/view/Sandbox/TdaqSwEclipse
Install Java and Eclipse
- If you do not have Java, please download and install it. Eclipse needs it.
- Download “Eclipse IDE for C/C++ Developers” from http://www.eclipse.org/downloads/
- Extract folder “eclipse” to a location where you want to store the executables. E.G. C:\Program Files\
- Enter the folder and execute “eclipse”. It will ask you for location of the workspace. That's where the source code is stored.
Install SVN plugins
- Run Eclipse and select Help > Install New Software… from the main menu.
- Enter “http://download.eclipse.org/releases/juno” in “work with” and click “Add…”
- Select “Collaboration –> Subversive SVN team provider” and install it.
- Restart Eclipse
- Select Help > Install New Software… from the main menu.
- Enter http://community.polarion.com/projects/subversive/download/eclipse/4.0/luna-site/ in “work with” and click “Add…”
- Select “Subversive SVN Connectors” and “SVN Kit” and install them.
- Restart Eclipse.
Access CERN SVN
- Window → Open perspective → SVN Repository Exploring
- Add New Repository Location. Enter svn+ssh:svn.cern.ch/reps/atlasoff as URL. Use your CERN username and password. - You can also do that to your private SVN repository. - Select AnalysisSUSY → trunk → packages.rc - Right click on the file and select “Show history” - Compare tag 620896 to the previous revision. - Now you can see what has changed. When the change was made. Who did that. The comments are also displayed. ===== Import a package from SVN ===== - Return to “C/C++ Perspective”: click the icon in the upper-right corner of the window. - Right-click on “Project Explorer” and click “import”. - Select “SVN” → “Project from SVN”. “Next” → “Browse”. - Navigate to PhysicsAnalysis → SYSYPhys → SUSYTools → tags → SUSYTools-00-05-00-13 - Select “Check out as a project with the name specified:”. The project will appear in the Project Explorer. - Go to src –> SUSYToolsAlg.cxx and double-click on the file. - Right-click on the project name. Select “New –> Covert to a C/C++ Project”. - Select “C Project. Uncheck “Specify project type”. - Now the syntax checking, indexing, and autocomplete are enabled.
asc/tutorials/eclipse.1414594507.txt.gz · Last modified: 2014/10/29 14:55 by aparamonov
