Using data subscription
For large datasets, you can “subscribe” to the data. Go to DaTRI - User Requests and request a dataset. During the request, select “cloud” (“US”) and destination ANL-ATLAS-GRIDFTP1.
Read more here DataTransferRequestInterface
Users need to be registered to be able to submit data transfer or ATLAS production system requests. User registration page for DaTRI system: DDM user. If you do not want to register, ask S.Chekanov to trigger the request.
If problems with registration are appeared then user should place Savannah ticket at https://savannah.cern.ch/projects/dq2-ddm-ops/ (Support → Submit or Bugs → Submit) with category name “DaTRI – Data Transfer Request”.
After the subscription, you can check the status using the check the status link Your data will arrive to the ANL xrootd file server. Login to atlas16 or 18 and check:
/atlasfs/atlas/dq2/user/<Grid CA nickname>
If you need help. please as one of us (Doug Bengamin, Sergei Chekanov or Bob Blair)
— Sergei Chekanov 2013/03/18 09:19
