This tutorial is based on CERN SoftwareTutorialxAODAnalysisInROOT wiki. However, the lessons given below are simplified for a faster start. Also, the last 2 lessons are designed for the ANL cluster that uses condor for job submissions. In addition, we we will test US ATLAS connect as explained at the bottom of this page.
We would like to encourage you all to obtain a computer account already at your local Tier3. That is the recommended way to do the tutorials since, eventually, you may want to run your xAOD analysis at home institutes. If needed, we can also provide you an account at Argonne Tier3.
ANL people can use “atlas1.hep.anl.gov” or atlas2.hep.anl.gov.
First, we will setup ATLAS release.
1) Setup kinit if needed: kinit [email protected] where username is your user name on lxplus. This step is normally not needed.
2) Create a bash script to setup ATLAS software. The method below works at ANL:
#!/bin/bash export ALRB_localConfigDir="/share/sl6/cvmfs/localConfig" export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh #asetup 19.1.1.4,slc6,here # setup ATLAS release when needed setupATLAS
and then do “source setup.sh”. This works at ANL/ASC. Make a similar script when using lxplus or other Tier3 as explained in CERN tutorial.
On LXPLUS:
export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase alias setupATLAS='source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh' setupATLAS
To run tutorials, you can check these requirements (prepared by Asoka De Silva):
setupATLAS diagnostics checkOS
setupATLAS diagnostics gridCert
You will need 500 MB of free space. It can be $HOME or any other location - note the location as you will be asked for it. If you are running on lxplus, you can request your home dir quota be increased to 10GB or request up to an additional 100GB of workspace. To ask for space, go to (use your lxplus username below)
https://resources.web.cern.ch/resources/Manage/AFS/Settings.aspx?login=<your lxplus username>
You may need to request repeatedly to get the full quota (it is granted in increments.). To check how much quota you have on /afs (eg on lxplus), type fs lq; eg.
fs lq /afs/cern.ch/user/d/desilva fs lq /afs/cern.ch/work/d/desilva # for workspace if you have it
Let's us take a look at a typical xAOD file. You can open it with ROOT TBrowser to study its structure.
mkdir lesson_1 cd ./lesson_1
If you want to get an example xAOD file without running the above command, let's do it slowly:
Method 1. If you are at ANL, copy it:
cp /data/nfs/chakanau/tutorial_xAOD_long/valid2.117050.PowhegPythia_P2011C_ttbar.digit.AOD.e2657_s1933_s1964_r5534_tid01482225_00/AOD.01482225._000140.pool.root.1 AOD.01482225._000140.pool.root
Method 2. Use xrdcp:
localSetupFAX --rootVersion=current-SL6 voms-proxy-init -voms atlas xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000140.pool.root.1 AOD.01482225._000140.pool.root
Method 3: If you work at CERN, use this file:
/afs/cern.ch/atlas/project/PAT/xAODs/r5597/data12_8TeV.00204158.physics_JetTauEtmiss.recon.AOD.r5597/AOD.01495682._003054.pool.root.1 /afs/cern.ch/atlas/project/PAT/xAODs/r5591/mc14_8TeV.117050.PowhegPythia_P2011C_ttbar.recon.AOD.e1727_s1933_s1911_r5591/AOD.01494882._111853.pool.root.1
Method 4: If you work at your Tier3
setupATLAS diagnostics setMeUpData anl-oct2014 mydata
The file will appear in “mydata/tutorial/anl-oct2014/datase/” directory
Now open this file with TBrowser:
root TBrowser a
Click the file name using the left panel, Select “CollectionTree” and find a branch with the extension “Aux” (for example, “AntiKt4TruthJetsAux”) and then plot “AntiKt4TruthJetsAux.pt”. See other detail in CERN tutorial
Now we will read the above line in Python and print some values for electron (eta and phi)
First, we setup our environment in the directory “lesson_1” that has the xAOD file:
source setup.sh rcSetup -u; rcSetup Base,2.0.12
Now you can check what versions of packages are linked:
rc version
that shows a long version of package versions.
The let's create a new directory and put this file:
#!/usr/bin/env python # Set up ROOT and RootCore: import ROOT ROOT.gROOT.Macro( '$ROOTCOREDIR/scripts/load_packages.C' ) ROOT.xAOD.Init() # Initialize the xAOD infrastructure fileName="AOD.01482225._000140.pool.root" # Set up the input files treeName = "CollectionTree" # default when making transient tree anyway f = ROOT.TFile.Open(fileName) t = ROOT.xAOD.MakeTransientTree( f, treeName) # Make the "transient tree" # Print some information: print( "Number of input events: %s" % t.GetEntries() ) for entry in xrange( t.GetEntries() ): t.GetEntry( entry ) print( "Processing run #%i, event #%i" % ( t.EventInfo.runNumber(), t.EventInfo.eventNumber() ) ) print( "Number of electrons: %i" % len( t.ElectronCollection ) ) for el in t.ElectronCollection: # loop over electron collection print( " Electron trackParticle eta = %g, phi = %g" % ( el.trackParticle().eta(), el.trackParticle().phi() ) ) pass # end for loop over electron collection pass # end loop over entries f.Close()
If you copy this script, correct indentation (the lines should start from the column position 0). This is a good for your to learn this code! Then run it as:
chmod +x xAODPythonMacro.py ./xAODPythonMacro.py
Using this code, one can fill histograms. But the code runs slow. Below we will show how to use C++/ROOT compiled code to run over this file.
How will you find xAOD variables without using ROOT TBrowser? Try this code:
asetup 19.1.1.1,slc6,gcc47,64,here
checkSG.py AOD.01482225._000140.pool.root
You will see a table with the names of the variables.
Now you can fill a histogram in this Python code. You should create a histogram before the event loop:
from ROOT import * h1=TH1D("eta","eta",20,-4,4)
Then fill it in the event loop as h1.Fill( el.trackParticle().eta() ). Then we will write this histogram in a file as:
hfile=TFile("test.root","RECREATE","ANL tutorial") h1.Write() hfile.Close()
Here the code that write a ROOT histogram:
#!/usr/bin/env python import ROOT ROOT.gROOT.Macro( '$ROOTCOREDIR/scripts/load_packages.C' ) ROOT.xAOD.Init() # Initialize the xAOD infrastructure fileName="AOD.01482225._000140.pool.root" # Set up the input files treeName = "CollectionTree" # default when making transient tree anyway f = ROOT.TFile.Open(fileName) t = ROOT.xAOD.MakeTransientTree( f, treeName) # Make the "transient tree" from ROOT import * h1=TH1D("eta","eta",20, -4,4) # Print some information: print( "Number of input events: %s" % t.GetEntries() ) for entry in xrange( t.GetEntries() ): t.GetEntry( entry ) print( "Processing run #%i, event #%i" % ( t.EventInfo.runNumber(), t.EventInfo.eventNumber() ) ) print( "Number of electrons: %i" % len( t.ElectronCollection ) ) for el in t.ElectronCollection: # loop over electron collection h1.Fill( el.trackParticle().eta() ) pass # end for loop over electron collection pass # end loop over entries hfile=TFile("test.root","RECREATE","ANL tutorial") h1.Write() f.Close() hfile.Close()
Now open the file “test.root” and look at the histogram.
Now we will create a C++/ROOT analysis program and run over this input xAOD file. Do not forget to run “kinit [email protected]”. Use the same setup file as above.
source setup.sh mkdir lesson_3; cd lesson_3 rcSetup -u; rcSetup Base,2.0.12 rc find_packages # find needed packages rc compile # compiles them
This takes some time to compile. Next we will us a simple example code that runs over multiple files located in some directory
curl http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/MyAnalysis_lesson3.tgz | tar -xz; rc find_packages # find this package rc compile # compiles it cd MyAnalysis/util # go to the analysis code
We are ready to run the code, which is “testRun.cxx” But we first should define a list with input data. This example reads file “inputdata.txt” with location of xAOD files. You can create it as:
python Make_input <directory with xAOD files>
Now the input file is ready and we run the example as.
In case if you need xAOD data, do this:
mkdir data cd data localSetupFAX --rootVersion=current-SL6 voms-proxy-init -voms atlas xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000140.pool.root.1 . xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000141.pool.root.1 . xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000142.pool.root.1 .
This will copy 3 test files. and run:
cd .. python Make_input data
Now we are ready to run:
testRun submitDir # runs over all files inside inputdata.txt
We pass “submitDir” which will be the output directory with ROOT file. You must delete it every time you run the code (or use different output). The actual analysis should be put to “Root/MyxAODAnalysis.cxx” (will come back to this later). The output histogram is ”“submitDir/hist-sample.root” (which is almost empty).
Now we will make a number of changes to the above program. For a quick start, do this:
source setup.sh mkdir lesson_4; cd lesson_4
Next we will make a simple example code that runs over multiple files located in some directory.
curl http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/MyAnalysis_lesson4.tgz | tar -xz; wget http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/data12_8TeV.periodAllYear_DetStatus-v61-pro14-02_DQDefects-00-01-00_PHYS_StandardGRL_All_Good.xml rc find_packages # find this package rc compile # compiles it cd MyAnalysis/util # go to the analysis code
Now prepare an input file with the data from a directory with xAOD files:
and run the analysis:
How does this work? Your analysis code is testRun.cxx. We pass “submitDir” which will be the output directory with ROOT file. The actual analysis should be put to “Root/MyxAODAnalysis.cxx” as explained above. This example has an access to muon and jet containers, plus it reads goodrunlist. This is what was done:
1) We linked several ATLAS packages.
PACKAGE_DEP = EventLoop xAODRootAccess xAODEventInfo GoodRunsLists xAODJet xAODTrigger xAODEgamma JetSelectorTools JetResolution xAODMuon
in “cmt/Makefile.RootCore”. We linked more packaged than needed to illustrate what can be linked. Use “rc version” to check their versions.
2) Then we modified 2 places to put histograms
MyAnalysis/MyxAODAnalysis.h # used to define pointers to histograms Root/MyxAODAnalysis.cxx # initialized histograms and our analysis code that loops over jets and muons
The output of this example is in “submitDir/hist-sample.root”. Open it with ROOT:
root TBrowser a
and look at the histograms of jet and muon pT.
Now we run the above job on multiple cores of same computer and merge histogram outputs at the end. The execution of this program does not use anything from ATLAS. It uses basic Linux commands. Prepare a fresh directory:
source setup.sh mkdir lesson_5; cd lesson_5
And setup the package:
curl http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/MyAnalysis_lesson5.tgz | tar -xz; rc find_packages # find this package rc compile # compiles it cd MyAnalysis/util # go to the analysis code
For ANL people, the file “inputdata.txt” is already filled with xAOD data. If you use another Tier3, you need to copy several xAOD files (as for the lesson 3), put them to some directory “dir” and run “python Make_input dir” which creates a new “inputdata.txt”.
Also pay attention to the location of goodrunlist inside Root/MyxAODAnalysis.cxx. Correct the location of the goodrunlist as you did for lesson 4.
We have made a few changes for in this lesson compared to lesson 4. For example, we changed 'testRun.cxx' file and included a small script “A_RUN” that launches several jobs in parallel. Open the file “A_RUN” and study it. What it does is this:
The output will go to the directory “outputs”, while input files and logfiles will be put to “inputs” directory.
Now run “./A_RUN” to launch 2 jobs using 2 cores. Each job will read a portion of the original “inputdata.txt”
You can monitor jobs with this command (launched in a separate terminal):
ps rux | grep -e "testRun"
When the jobs are done, you can merge the output files to “hist.root”:
hadd -f hist.root outputs/*/hist-run*.root
If it does not work: Debug it as:
testRun 00
This will process inputs/list00 (first part of the input list) and shows where the problem is. (Typically, this is due to wrong location of the goodrunlist).
Attention:
This example is ANL-specific. If you ran analysis code for RUN I, you should be a familiar with it. We used Condor/Arcod system to submit jobs to the farm. Data are distributed on the farm nodes to avoid IO bottleneck.
First, create a directory for this example:
Prepare a fresh directory and populate with the next example:
mkdir lesson_6; cp -r /users/chakanau/public/2014_tutorial_october_anl/lesson_6/* lesson_6/
Then check that you can compile the analysis example using RootCore:
cd lesson_6/ source setup.sh
As usual, our analysis is in “MyAnalysis/util/testRun.cxx”. Now we want to submit jobs to the data distributed on several computers of the farm. Go to the upper directory and setup the farm:
cd ../; source s_asc;
We will send jobs using the directory “submit”. Go to this directory and check the data:
cd submit arc_ls -s /data2/valid2/117050/PowhegPythia_P2011C_ttbar.digit.AOD.e2657_s1933_s1964_r5534/ # shows short summary of data arc_ls /data2/valid2/117050/PowhegPythia_P2011C_ttbar.digit.AOD.e2657_s1933_s1964_r5534/ # list all files
The first command shows the summary of distributed data (12 files per server), while the second lists all available data on each node. Now we will send the job to the farm. Change the line:
package_dir=/users/chakanau/public/2014_tutorial_october_anl/lesson_6/ANLanalysis
inside “arcond.conf” to reflect the correct path to your program. Then run “arcond” and say “y” to all questions. This sends jobs to the farm (2 jobs per server). Check the status as:
condor_q
When the jobs are done, the output files will be inside “Jobs” directory. Merge the ROOT outputs into one file as:
arc_add
This will create the final output file “Analysis_all.root”
Now we need to get an example xAOD file. You can do all the checks above plus data for this tutorial as:
setupATLAS diagnostics setMeUp anl-oct2014
(this may fail on certain Tier3s)
This set of tutorials uses ATLAS connect. Please go to the link using ATLAS connect. All lessons discussed on this wiki have been adopted by Ilija Vukotic for the use with ATLAS connect.
See the instruction on how to use ATLAS connect for this tutorial
Sergei Chekanov (ANL) 2014/10/09 13:50
