This tutorial is based on CERN SoftwareTutorialxAODAnalysisInROOT wiki. However, the lessons given below are simplified for a faster start. Also, the last 2 lessons are designed for the ANL cluster that uses condor for job submissions. In addition, we we will test US ATLAS connect as explained at the bottom of this page.
We would like to encourage you all to obtain a computer account already at your local Tier3. That is the recommended way to do the tutorials since, eventually, you may want to run your xAOD analysis at home institutes. If needed, we can also provide you an account at Argonne Tier3.
ANL people can use “atlas1.hep.anl.gov” or atlas2.hep.anl.gov.
First, we will setup ATLAS release.
1) Setup kinit if needed: kinit [email protected] where username is your user name on lxplus. This step is normally not needed.
2) Create a bash script to setup ATLAS software. The method below works at ANL:
#!/bin/bash export ALRB_localConfigDir="/share/sl6/cvmfs/localConfig" export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh #asetup 19.1.1.4,slc6,here # setup ATLAS release when needed setupATLAS
and then do “source setup.sh”. This works at ANL/ASC. Make a similar script when using lxplus or other Tier3 as explained in CERN tutorial.
On LXPLUS:
export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase alias setupATLAS='source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh' setupATLAS
To run tutorials, you can check these requirements (prepared by Asoka De Silva):
setupATLAS diagnostics checkOS
setupATLAS diagnostics gridCert
You will need 500 MB of free space. It can be $HOME or any other location - note the location as you will be asked for it. If you are running on lxplus, you can request your home dir quota be increased to 10GB or request up to an additional 100GB of workspace. To ask for space, go to (use your lxplus username below)
https://resources.web.cern.ch/resources/Manage/AFS/Settings.aspx?login=<your lxplus username>
You may need to request repeatedly to get the full quota (it is granted in increments.). To check how much quota you have on /afs (eg on lxplus), type fs lq; eg.
fs lq /afs/cern.ch/user/d/desilva fs lq /afs/cern.ch/work/d/desilva # for workspace if you have it
Let's us take a look at a typical xAOD file. You can open it with ROOT TBrowser to study its structure.
mkdir lesson_1 cd ./lesson_1
Now we need to get an example xAOD file. You can do all the checks above plus data for this tutorial as:
setupATLAS diagnostics setMeUp anl-oct2014
If you want to get an example xAOD file without running the above command, let's do it slowly:
Method 1. If you are at ANL, copy it:
cp /data/nfs/chakanau/tutorial_xAOD_long/valid2.117050.PowhegPythia_P2011C_ttbar.digit.AOD.e2657_s1933_s1964_r5534_tid01482225_00/AOD.01482225._000140.pool.root.1 AOD.01482225._000140.pool.root
Method 2. Use xrdcp:
localSetupFAX --rootVersion=current-SL6 voms-proxy-init -voms atlas xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000140.pool.root.1 AOD.01482225._000140.pool.root
Method 3: If you work at CERN, use this file:
/afs/cern.ch/atlas/project/PAT/xAODs/r5597/data12_8TeV.00204158.physics_JetTauEtmiss.recon.AOD.r5597/AOD.01495682._003054.pool.root.1 /afs/cern.ch/atlas/project/PAT/xAODs/r5591/mc14_8TeV.117050.PowhegPythia_P2011C_ttbar.recon.AOD.e1727_s1933_s1911_r5591/AOD.01494882._111853.pool.root.1
Method 4: If you work at your Tier3
setupATLAS diagnostics setMeUpData anl-oct2014 mydata
The file will appear in “mydata/tutorial/anl-oct2014/database/” directory
Now open this file with TBrowser:
root TBrowser a
Click the file name using the left panel, Select “CollectionTree” and find a branch with the extension “Aux” (for example, “AntiKt4TruthJetsAux”) and then plot “AntiKt4TruthJetsAux.pt”. See other detail in CERN tutorial
Now we will read the above line in Python and print some values for electron (eta and phi)
First, we setup our environment in the directory “lesson_1” that has the xAOD file:
source setup.sh rcSetup -u; rcSetup Base,2.0.12
Now you can check what versions of packages are linked:
rc version
that shows a long version of package versions.
The let's create a new directory and put this file:
#!/usr/bin/env python # Set up ROOT and RootCore: import ROOT ROOT.gROOT.Macro( '$ROOTCOREDIR/scripts/load_packages.C' ) ROOT.xAOD.Init() # Initialize the xAOD infrastructure fileName="AOD.01482225._000140.pool.root" # Set up the input files treeName = "CollectionTree" # default when making transient tree anyway f = ROOT.TFile.Open(fileName) t = ROOT.xAOD.MakeTransientTree( f, treeName) # Make the "transient tree" # Print some information: print( "Number of input events: %s" % t.GetEntries() ) for entry in xrange( t.GetEntries() ): t.GetEntry( entry ) print( "Processing run #%i, event #%i" % ( t.EventInfo.runNumber(), t.EventInfo.eventNumber() ) ) print( "Number of electrons: %i" % len( t.ElectronCollection ) ) for el in t.ElectronCollection: # loop over electron collection print( " Electron trackParticle eta = %g, phi = %g" % ( el.trackParticle().eta(), el.trackParticle().phi() ) ) pass # end for loop over electron collection pass # end loop over entries f.Close()
If you copy this script, correct indentation (the lines should start from the column position 0). This is a good for your to learn this code! Then run it as:
chmod +x xAODPythonMacro.py ./xAODPythonMacro.py
Using this code, one can fill histograms. But the code runs slow. Below we will show how to use C++/ROOT compiled code to run over this file.
How do you know about methods of “el.trackParticle()”? You can print methods of this object as:
print dir(el.trackParticle())
How will you find xAOD variables without using ROOT TBrowser? Try this code:
asetup 19.1.1.1,slc6,gcc47,64,here
checkSG.py AOD.01482225._000140.pool.root
Now you can fill a histogram in this Python code. You should create a histogram before the event loop:
from ROOT import * h1=TH1D("eta","eta",20,-4,4)
Then fill it in the event loop as h1.Fill( el.trackParticle().eta() ). Then we will write this histogram in a file as:
hfile=TFile("test.root","RECREATE","ANL tutorial") h1.Write() hfile.Close()
Here the code that write a ROOT histogram:
#!/usr/bin/env python import ROOT ROOT.gROOT.Macro( '$ROOTCOREDIR/scripts/load_packages.C' ) ROOT.xAOD.Init() # Initialize the xAOD infrastructure fileName="AOD.01482225._000140.pool.root" # Set up the input files treeName = "CollectionTree" # default when making transient tree anyway f = ROOT.TFile.Open(fileName) t = ROOT.xAOD.MakeTransientTree( f, treeName) # Make the "transient tree" from ROOT import * h1=TH1D("eta","eta",20, -4,4) # Print some information: print( "Number of input events: %s" % t.GetEntries() ) for entry in xrange( t.GetEntries() ): t.GetEntry( entry ) print( "Processing run #%i, event #%i" % ( t.EventInfo.runNumber(), t.EventInfo.eventNumber() ) ) print( "Number of electrons: %i" % len( t.ElectronCollection ) ) for el in t.ElectronCollection: # loop over electron collection h1.Fill( el.trackParticle().eta() ) pass # end for loop over electron collection pass # end loop over entries hfile=TFile("test.root","RECREATE","ANL tutorial") h1.Write() f.Close() hfile.Close()
Now open the root file and look at the histogram.
Now we will create a C++/ROOT analysis program and run over this input xAOD file. Use the same setup file as above.
source setup.sh mkdir lesson_3; cd lesson_3 rcSetup -u; rcSetup Base,2.0.12 rc find_packages # find needed packages rc compile # compiles them
This takes some time to compile. Next we will us a simple example code that runs over multiple files located in some directory
curl http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/MyAnalysis_lesson3.tgz | tar -xz; rc find_packages # find this package rc compile # compiles it cd MyAnalysis/util # go to the analysis code
We are ready to run the code, which is “testRun.cxx” But we first should define a list with input data. This example reads file “inputdata.txt” with location of xAOD files. You can create it as:
python Make_input <directory with xAOD files>
In case if you need xAOD data, do this:
mkdir data cd data localSetupFAX --rootVersion=current-SL6 voms-proxy-init -voms atlas xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000140.pool.root.1 . xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000141.pool.root.1 . xrdcp $STORAGEPREFIX/atlas/rucio/valid2:AOD.01482225._000142.pool.root.1 .
and run:
cd .. python Make_input data
Now inputdata.txt should pick up your xAOD files.
Now the input file is ready and we run the example as:
testRun submitDir # runs over all files inside inputdata.txt
We pass “submitDir” which will be the output directory with ROOT file. You must delete it every time you run the code (or use different output). The actual analysis should be put to “Root/MyxAODAnalysis.cxx” (will come back to this later). The output histogram is ““submitDir/hist-sample.root” (which is almost empty).
Now we will make a number of changes to the above program. We will fill 2 histograms with pT of jets and muons. To do this we will need a number of changes:
1) We need to link several ATLAS packages.
PACKAGE_DEP = EventLoop xAODRootAccess xAODEventInfo GoodRunsLists xAODJet xAODTrigger xAODEgamma JetSelectorTools JetResolution xAODMuon
in “cmt/Makefile.RootCore”. We linked more packaged than needed to illustrate what can be linked. Use “rc version” to check their versions.
2) Then we need to modify 2 places to put histograms
MyAnalysis/MyxAODAnalysis.h # used to define pointers to histograms Root/MyxAODAnalysis.cxx # initialized histograms and our analysis code that loops over jets and muons
Let us run this code to see how it works:
source setup.sh mkdir lesson_4; cd lesson_4
Next we will us a simple example code that runs over multiple files located in some directory.
curl http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/MyAnalysis_lesson4.tgz | tar -xz; wget http://atlaswww.hep.anl.gov/asc/xaod_tutor_oct2014/data12_8TeV.periodAllYear_DetStatus-v61-pro14-02_DQDefects-00-01-00_PHYS_StandardGRL_All_Good.xml rc find_packages # find this package rc compile # compiles it cd MyAnalysis/util # go to the analysis code
Now prepare an input file with data from a directory with xAOD files:
and run the analysis:
How does this work? Your analysis code is testRun.cxx. We pass “submitDir” which will be the output directory with ROOT file. The actual analysis should be put to “Root/MyxAODAnalysis.cxx” as explained above. This example has an access to muon and jet containers, plus it reads goodrunlist.
The output of this example is in “submitDir/hist-sample.root”. Open it with ROOT:
root TBrowser a
and look at the histograms with jet and muon pT.
— Sergei Chekanov 2014/10/28 07:49
