asc:tutorials:2014october_connect [2014/10/10 15:15] asc [Lesson 6: Using HTCondor and Tier2] |
asc:tutorials:2014october_connect [2014/10/10 15:26] asc [Lesson 6: Using HTCondor and Tier2] |
Line 214: | Line 214: | ||
In this example we will use HTCondor workload management system to send the job to be executed in a queue at a Tier3 farm. For this example we will start from the directory lesson 4, so if you did not do the lesson 4 please do that one first and verify that your code runs locally. | In this example we will use HTCondor workload management system to send the job to be executed in a queue at a Tier3 farm. For this example we will start from the directory lesson 4, so if you did not do the lesson 4 please do that one first and verify that your code runs locally. | ||
Start from the new shell and set up environment, | Start from the new shell and set up environment, | ||
- | startJob.sh | ||
<file bash startJob.sh> | <file bash startJob.sh> | ||
Line 243: | Line 242: | ||
Make sure the RUCIO_ACCOUNT variable is properly set. Make this file executable and create the file that describes our job needs and that we will give to condor: | Make sure the RUCIO_ACCOUNT variable is properly set. Make this file executable and create the file that describes our job needs and that we will give to condor: | ||
- | <code bash> | + | <file bash job.sub> |
- | job.sub | + | |
Jobs=10 | Jobs=10 | ||
getenv | getenv | ||
Line 257: | Line 255: | ||
queue $(Jobs) | queue $(Jobs) | ||
- | </code> | + | </file> |
To access files using FAX the jobs need a valid grid proxy. That's why we send it with each job. Proxy is the file starting with " | To access files using FAX the jobs need a valid grid proxy. That's why we send it with each job. Proxy is the file starting with " | ||
Line 263: | Line 261: | ||
You need to pack all of the working directory into a payload.zip file: | You need to pack all of the working directory into a payload.zip file: | ||
- | <code bash> | + | <file bash startJob.sh> |
startJob.sh | startJob.sh | ||
rc clean | rc clean | ||
rm -rf RootCoreBin | rm -rf RootCoreBin | ||
zip -r payload.zip * | zip -r payload.zip * | ||
Now you may submit your task for the execution and follow its status in this way: | Now you may submit your task for the execution and follow its status in this way: | ||
- | startJob.sh | + | |
+ | chmod 755 ./ | ||
<code bash> | <code bash> |
