Select “Subversive SVN Connectors” and “SVN Kit” and install them.
Restart Eclipse.
Access CERN SVN
Window → Open perspective → SVN Repository Exploring
Add New Repository Location. Enter “svn+ssh:svn.cern.ch/reps/atlasoff”
- Use your CERN username and password.
- You can also do that to your private SVN repository.
- Select AnalysisSUSY → trunk → packages.rc
- Right click on the file and select “Show history”
- Compare tag 620896 to the previous revision.
- Now you can see what has changed. When the change was made. Who did that. The comments are also displayed.
===== Import a package from SVN =====
- Return to “C/C++ Perspective”: click the icon in the upper-right corner of the window.
- Right-click on “Project Explorer” and click “import”.
- Select “SVN” → “Project from SVN”. “Next” → “Browse”.
- Navigate to PhysicsAnalysis → SYSYPhys → SUSYTools → tags → SUSYTools-00-05-00-13
- Select “Check out as a project with the name specified:”. The project will appear in the Project Explorer.
- Go to src –> SUSYToolsAlg.cxx and double-click on the file.
- Right-click on the project name. Select “New → Covert to a C/C++ Project”.
- Select “C Project. Uncheck “Specify project type”.
- Now the syntax checking, indexing, and autocomplete are enabled.
asc/tutorials/eclipse.1414594647.txt.gz · Last modified: 2014/10/29 14:57 by aparamonov
