To start using this wiki, forum and the download area, you should become a member. For this, you should register here.
Below we describe the computing environment of the ANL ATLAS cluster. Some users, especially visitors, are welcome to use the Atlas support center cluster which has additional resources. You can look at the instructions here
At ANL ASC one can use any of these “interactive” servers with public ssh login from outside. All computers are based on Scientific Linux 5.3. Public ssh login servers:
name | cores Linux | note |
atlas15.hep.anl.gov | 8 SL5.7 | Public login for ALL ASC users |
atlas16.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users |
atlas17.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users |
atlas18.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users |
atlas1.hep.anl.gov | 16 SL6.4 | for ANL group and ANL-based visitors |
atlas2.hep.anl.gov | 16 SL6.4 | for ANL group and ANL-based visitors |
You should use ANL domain password and user name. All other computers can be accessed from the computers above. It should be noted that they require the ANL domain password and the user name.
Desktop computers do not have login from outside. The hostnames of the users desktops are atlas20 - atlas49.hep.anl.gov
Every interactive node mounts this central storage:
/atlasfs/atlas/local
Please check your name there.
In addition, every server has scratch space here:
/data1/ /data2/
atlas2 has more space in /data1, /data2, /data3, /data4.
Finally, you can use “atlas4” which mounts 20 TB of scratch space. atlas4 can be accessed after login to atlas1,2.
The computer farm has distributed data storage managed by ArCond. This will be described later.
The computer farm consists of 16 servers atlas50-65. Each server has 2 CPU with 8 cores and 5 TB of local disk space. The farm is based on SL6
The PC farm uses the Arcond for job submission which allows to share the resources and simplifies the data discovery. The backend of this farm is Condor. You can use it as well as long as you restrict your jobs to atlas50-65 and use 4 cores per server. If you have long jobs, please use the old farm. Login to the computer farm is not allowed.
You can see the current CPU usage using this web page ANL-ATLAS computer farm monitor. (can be accessed from inside ANL, or when using a proxy after atlas1 ssh). Alternatively, look at the Condor jobs monitor here ANL-ATLAS condor monitor.
You can run JCondor Monitoring GUI to monitor condor cluster:
/share/grid/app/asc_app/asc_rel/1.0/setup-script/set_asc.sh cp -rf /share/sl6/jcondor . cd jcondor java -jar jcondor.jar
About the scratch disk space: It is available on atlas1,2,16,17,18 (5TB for each server) and on every desktop. Every user has a directory under /data1 and /data2. The scratch disks do not have backup. You should use these disks if you do not want to gain speed for running/compiling your programs.
In some cases, you will need to access data from all computers. If data size is not large (not larger than 10 GB), one can put data on NFS: /data/nfs/users/ If you are interested in a larger sample, contact the administrator.
Please read the section Working with data at ANL Tier3 for details on how to store and process your data.
The default shell for the ANL ASC is bash. To setup the necessary environment (ROOT, SVN etc), run this script:
source /share/grid/app/asc_app/asc_rel/1.0/setup-script/set_asc.sh
Check this by running “root” or “condor_status”. You can also add the environmental variables automatically: Create '.bash_profile' file if it is not done yet, and put these lines:
alias ls='ls -F --color=auto' source /share/grid/app/asc_app/asc_rel/1.0/setup-script/set_asc.sh
This will set up the recent version of ROOT with the native PYTHON 2.4 from SL5.3. Alternatively, put the above lines to the file '.bashrc' or run this command:
At this point, no any atlas software is installed. Note that the same setup script also setup FASTJET and LHAPDF. Check this as
echo $FASTJET echo $LHAPDF
To setup ATLAS software from the packman, copy and save these lines in a file, say “set.sh”
export AVERS=17.8.0 export TEST_AREA=$HOME/testarea # ANL local setup for fronter export ALRB_localConfigDir="/share/sl6/cvmfs/localConfig" export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh asetup --release=$AVERS --testarea=$TEST_AREA
Then “source set.sh” every time you login on atlas16-28 computers. Note: you should use the bash shell for this setup. If you are happy with this, one can put this line in .bash_profile or .bashrc files (if you are using bash shell and want to set up the ATLAS staff every time you login). You can change the ATLAS release and testarea by changing “AVERS” and “TEST_AREA” variables.
You can also use packages compiled with RootCore. For SL6, they are located here:
/share/sl6/AtlasRootCoreLib
they were compiled against the native SL6 gcc (/usr/bin/gcc), native python (/usr/bin/python) and ROOT (source /share/grid/app/asc_app/asc_rel/1.0/setup-script/set_asc.sh). If you want to recompile such packages using a different ROOT, simply copy this directory to your directory, and run “A_COMPILE.sh” to recompile all these packages.
If you need to add more packages, get them with svn:
export SVNOFF=svn+ssh://svn.cern.ch/reps/atlasoff svn co $SVNOFF/Reconstruction/Jet/ApplyJetCalibration/tags/ApplyJetCalibration-00-03-15 ApplyJetCalibration
and run the script “A_COMPILE.sh” again.
It is mirrored at ANL. After setting up an ATLAS release, check $ATLAS_POOLCOND_PATH Normally, you do not need to do anything since athena should find this path.
If you will need different database release (rather than that included in the current athena release), put these lines in your setup:
export DBRELEASE_INSTALLDIR="/share/grid/DBRelease" export DBRELEASE_VERSION="9.6.1" export ATLAS_DB_AREA=${DBRELEASE_INSTALLDIR} export DBRELEASE_OVERRIDE=${DBRELEASE_VERSION}
Read more details here
(This is in case you need to start over with your session)<br />To remove the ATLAS release and all associated environmental variables and setting the ASC ANL environment only, use:
After executing this script, you will have an access to most recent self-contained ROOT installation and all other variables necessary to work at ASC (CVS, firefox etc). You can put this string, say in a file “clean”:
#!/bin/bash source /share/grid/app/asc_app/asc_rel/1.0/setup-script/set_asc.sh
so that when you want to clear the shell from ATLAS release, jut type “source clean”
Setup atlas release and do:
cd $ATLANTISJAVA_HOME /usr/bin/java -jar atlantis.jar
Here we assume release 15.6.1 and atlas16/17
Running VP1:
Setup atlas release, go to the testarea/[release] and type “vp1”
This is an alternative way to setup ATLAS releases and the grid. This setup uses a network-based file system from CERN and closely follows the lxplus setup.
This setup can only work on interactive nodes: atlas1,2,16,18
Login on atlas2.hep.anl.gov and do:
export ALRB_localConfigDir="/share/sl6/cvmfs/localConfig" # local to ANL config files (fronter condition database) export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh
Then follow the instructions. Typically, you can setup an atlas release as:
asetup --release=17.0.0 --testarea=/users/<user>/testarea
assuming that the directory ~<user>/testarea/AtlasOffline-17.8.0 exists
You can do
showVersions --show=athena
to list athena versions. (similarly for showVersions –show=dbrelease). Note that the conditions pool files catalog is setup once setupATLAS is done. (If cvmfs is available, its Athena/DBRelease versions will also be listed; otherwise, only local disk versions are listed.)
When setting us “pathena”, avoid using DQ2 setup:
asetup 17.8.0,slc6,gcc47 localSetupPandaClient
Use DQ2 get setup in a different window!:
localSetupDQ2Client
Your typical setup script may look as:
#!/bin/bash export AVERS=17.8.0 export TEST_AREA=$HOME/testarea export ALRB_localConfigDir="/share/sl6/cvmfs/localConfig" # local to ANL config files (fronter condition database) export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh asetup --release=$AVERS --testarea=$TEST_AREA
then do “source setup.sh” to setup it.
After running the setup shown above, execute
localSetupDQ2Client --skipConfirm
You'll get a banner and then type the password.
Say “yes”. It's safest to dedicate a window for DQ2, or log out and in after using DQ2 if you want to use Athena.
Then type:
voms-proxy-init -voms atlas -valid 96:00
Read more about dq2-get and other grid services here.
Read additional information on how to use ATLASLocalRootBase
You may use xrootd on the interactive nodes. Login to atlas16 or atlas18, and try to copy file to the XROOTD user space on the farm:
rdcp test.txt xroot://atlashn1.hep.anl.gov:1094//atlas/USER/test/text.txt
(replace USER with your user name).
Similarly, use other XROOD commands. For example, remove this file:
rmdir xroot://atlashn1.hep.anl.gov:1094//atlas/USER/test.txt
On atlas16,18 you have a “common” data space. Check it the directory:
/atlasfs/atlas/local/
See also the link workbook_xrootd.
Please read this Section Working with the data
— Sergei Chekanov 2011/03/09 17:17
