Look at the WebSVN at ANL. Click on the necessary package and download it as a tar file.
To start using SVN at ANL, setup the variable SVNROOT in your .bashrc file as:
export SVNROOT=/users/svn
No, you can try to get ANL packages. This example shows how to retrieve “HighETjets” package:
svn co file:///$SVNROOT/HighETjets/HighETjets/trunk HighETjets
This will copy the trunk into the “HighETjets” directory. Similarly, one can retrive any package shown in WebSVN
The general rule to retrive a package is the command:
svn co file:///$SVNROOT/[Package]/[Package]/trunk [Package]
where [Package] is your package name.
If you decide to make updates of the package, use the link SoftwareDevelopmentWorkBookSVN for more information.
Generally, this is what you should do: cd inside the package (i.e., from where you can see “cmt”, “share”,“src” directories) and type:
svn update svn ci -m " put here some comment"
If you setup atlas release, this variable will not be set correctly, so always check “$SVNROOT”. Then use svn commands as usual. For example, to put a new package (MyPackage), use this example:
svnadmin create --fs-type fsfs /users/svn/MyPackage svn mkdir file:///users/svn/MyPackage/MyPackage svn import . file:///users/svn/MyPackage/MyPackaga/trunk -m "Initial import"
or send email to me ([email protected]) to create a new directory in the svn repository. To make the package to be visible on WebSVN, send email to me and I'll synchronize this directory with the web server.
Look at the SVN twiki As before, run the command:
/usr/kerberos/bin/kinit [email protected]
“username” is your username at CERN. This works on SL 5x computers.
If you are using SL6x, just use:
Then you should export this variable:
export SVNROOT=svn+ssh://svn.cern.ch/reps/atlasoff
In order to access a project using SSH authentication, just execute this:
$ svn co svn+ssh://svn.cern.ch/reps/<your_project>
or if you use a different username for LXPLUS:
$ svn co svn+ssh://<lxplus_username>@svn.cern.ch/reps/<your_project>
Or you can do this: If your name at CERN different, you should create a file “config” inside “.ssh” directory and add:
Host svn.cern.ch User USER_NAME_AT_CERN GSSAPIAuthentication yes GSSAPIDelegateCredentials yes Protocol 2 ForwardX11 no
replace USER_NAME_AT_CERN by your actual user name at CERN).
If you are not at CERN, see configuration advice for Windows and Linux/Unix, or just log on LXPLUS at CERN:
$ ssh <your_username>@lxplus.cern.ch
In order to access a project using https authorization, just execute this:
$ svn co https://svn.cern.ch/reps/<your_project>
— Sergei Chekanov 2011/03/09 17:30
