community:hepsim:dev_full
Creating full detector simulations
To create full simulations, you will need to convert ProMC files to LCIO files. This is described in converting_to_lcio
UNDER CONSTRUCTION
Pandora PFA
All information required by Pandora algorithm is stored in the file with the extension “.pandora”. This file is created using GeoConvertor, which reads CalorimeterCalibration.properties file. In particular, it reads:
- mipEnergy
- mipSigma
- mipCut
- timeCut
and sampling fractions. Look at the file:
lcsim/detector-framework/src/main/java/org/lcsim/geometry/compact/converter/pandora/Main.java
community/hepsim/dev_full.1476802624.txt.gz · Last modified: 2016/10/18 14:57 by asc
