community:hepsim:usage
How to analyse Monte Carlo event samples
Currently these studies are based on Jas4pp data-analysis environment. Geometry files for full detector simulations can be found in the detector repository.
Physics and detector studies
Here are several links to extending this Wiki for particular detector-performance topics:
- FCC-hh detector studies - explains how to analyses data for FCC-hh detector studies
- SID detector studies - explains how to analyses data for the SiD detector (ILC)
- CEPC detector studies - shows some results with full simulations for CEPC
- EIC detector studies - shows some results with full simulations for EIC
- HCAL studies explains how to analyse ROOT data after fast detector simulations used for FCC studies
This manual describes how to work with truth-level samples posted on HepSim. HepSim Python/Java analysis page explains how to write code to read truth-level files using Python on the Java platform.
community/hepsim/usage.1461765680.txt.gz · Last modified: 2016/04/27 14:01 by asc
