User Tools
Site Tools
community:hepsim:dev_hepsim
<< back to HepSim manual
How to link private samples to HepSim
Your files can be published on HepSim and you can maintain your own HepSim repository with PROMC/SLCIO/ROOT files. This is useful if:
  • You want to share your own files, so they will be available from HepSim
  • You want to make a mirror of data on a server close to your location for faster download
If the dataset is new, you will see a new entry in the HepSim database. Your authorship will be preserved on the HepSim web page. If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset.
What do you need
You need the following:
  • A web server that can hold your data (>1 TB for /var/www/html is recommended). It is advisable to create a separate partition with RAID10, say, /data, and link this directory to /var/www/html/.
  • Linux OS (any flavor)
  • Apache2 with PHP module that can serve/var/www/html/ and Java (optionally, for tools to check data)
The root directory of a typical HepSim repository has the name “events”. This directory should be served by Apache, i.e. it should be visible from /var/www/html. You will need to make the directory structure such as:
  |-events               # HepSim root directory
  |  |-pp                # process type: pp, ee, ep, misc (single particles)
  |  |  |-14tev          # CM energy. Can be 100tev, 250gev, 500gev
  |  |  |  |-qcd_pythia8 # this directory contains ProMC files for EVGEN
  |  |  |  |  |-rfast001 # subdirectory with ROOT/Delphes files
  |  |  |  |  |-rfull001 # subdirectory with SLCIO files
  |  |  |  |  |-macros   # files for truth validation (optional)
(it shows a data sample for 14 TeV pp with the name “qcd_pythia8”). The directory “events/pp/14tev/qcd_pythia8” should contain truth-level ProMC files. The sub-directories “rfast001” contains fast simulation files (tag “rfast001”), while “rfull001” should contain LCIO files with full simulation. The directory “macros” contains macro files written in Jython for validation, as well as images (optional).
After populating the directory “events/pp/14tev/qcd_pythia8” with ProMC files, you will need to index all files (including reconstruction tags). Install the needed packages as explained below. Download the example from hepsim_web.tgz Assuming that you are in the directory above the directory “events”, run these commands:
wget https://atlaswww.hep.anl.gov/asc/wikidoc/lib/exe/fetch.php?media=community:hepsim:hepsim_web.tgz -O hepsim_web.tgz
tar -zvxf hepsim_web.tgz
cd hepsim_web/web_post
wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz;
source hs-toolkit/setup.sh # this checks if Java is installed
This package has 2 directories:
  • events directory should be served by HTTP Apache. You can move it to /var/www/html location.
  • web_post directory should be outside the Apache area. This directory is used to index your files in the directory “events”
This package has 2 example files in “events/ee/250gev/pythia6_higgs_gamgam” to illustrate how the indexing works.
Now, index all ProMC/ROOT/SLCIO files located in “events”. Open the script “A_RUN_hepsim.sh” and specify the location of the “events” directory. Then run “bash ./A_RUN_hepsim.sh”. It will process the directory “events/”. You can edit the script to change the indexed directory to ““events/pp/100tev/”. After indexing, several new files should appear, such as “files.zip”, “metadata.txt” and “dirs.idx”.
To make sure that everything works, look with the browser in the HTTP link “http://yourserver/events/”. You should see your files and the directory structure. Note that what you see is not what you see in HepSim, which does not use the “index.php” file.
Now you can:
  • populate the directory tree with your files (for a new dataset). ProMC is used for EVGEN files, abd SLCIO/ROOT files for directories “rfullXXX/rfastXXX”, where XXX is a tag number.
  • copy existing files from the HepSim and put them to the correct directory (will be mirror)
In both cases, make sure that Linux system administrator set correct permission for the directory “events”, so you can copy the files. The directory for indexing should be inside your private directory outside the Web area.
If you have indexed the files successfully, send a request to “[email protected]” (or [email protected]) to include your repository to HepSim database. Please include a short description of your files and your name (it will be shown on the web page).
How to mirror entire dataset
You can mirror an entire dataset by copying HepSim files to your mirror web server (or local computer). You can use the command “hs-mirror” from the “hs-toolkit” package. For example, if you want to mirror a dataset with known URL, use this example:
source hs-toolkit/setup.sh # setup HepSim programs
# now copy a dataset from URL to a new location
SOURCE=http://cepcgit.ihep.ac.cn:81/hepsim/events/ee/250gev/pythia6_higgs_gamgam_test
OUTPUT_DIR=/var/www/html/
hs-mirror -i $SOURCE-o $OUTPUT_DIR
This example creates the directory ”/var/www/html/events/ee/250gev/pythia6_higgs_gamgam_test“ and copies all files from the URL. The URL can be found using the HepSim web page.
If you want to download only EVGEN files, without reconstructed events, use this command:
hs-mirror -i $SOURCE-o $OUTPUT_DIR -t evgen
Generally, you do not need to index files in the mirror directory.
Summary
When everything is done, this is what you will expect:
  • You files will be visible on the main HepSim web page and on the current mirrors (takes ~ few days to propagate the changes)
  • You can search your files etc. using the main HepSim web page
  • You can search, list and download files using hs-toolkit commands (hs-find, hs-ls, hs-get etc)
  • Since your files are public, there is good chance that somebody will make a mirror to reduce the load on your server
  • You server will be listed on the page statistics summary
Sergei Chekanov 2016/04/28 21:31Sergei Chekanov 2016/10/24 21:31
community/hepsim/dev_hepsim.1482421637.txt.gz · Last modified: 2016/12/22 15:47 by asc
