Single particle samples are created using the ProMC Java package. An example implemented in Jython is given in Dmelt example page. You will need to run either DMelt or Jas4pp to create single-particle sample using the Jython script. You can modify this script to change pT, Eta etc.
— Sergei Chekanov 2016/08/02 14:04
