community:refhepsim_analysis [2015/10/23 01:02] asc |
community:refhepsim_analysis [2016/04/28 15:24] asc [HepSim Analysis Primer] |
Line 17: | Line 17: | ||
+ | * [[http:// | ||
Line 203: | Line 204: | ||
print "pT of a leading jet =", | print "pT of a leading jet =", | ||
- | To build anti-kT jets, we use [[http:// | + | To build anti-kT jets, we use [[http:// |
+ | The description of this algorithm is given in [[http:// | ||
+ | It is a similar to FastJet N*N algorithm and typically shows | ||
a performance similar to the C++ analogue. Tests indicate that the JetN2 clustering algorithm is about twice slower that C++, but by a factor 20 faster than the traditional N^3 jet clustering algorithms. You can find benchmarking results in [[https:// | a performance similar to the C++ analogue. Tests indicate that the JetN2 clustering algorithm is about twice slower that C++, but by a factor 20 faster than the traditional N^3 jet clustering algorithms. You can find benchmarking results in [[https:// | ||
Look at a typical example of jet clustering in the [[http:// | Look at a typical example of jet clustering in the [[http:// | ||
Line 277: | Line 280: | ||
- | * [[http:// | + | * [[http:// |
