hpc:bghep:manual
BG-HEP manual
(S.Chekanov, E.May)
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of Argonne Leadership Computing Facility. The main features of the BG-HEP library are:
- Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls
- Monte Carlo / NLO programs redesigned to use MPI for random seeds and outputs on multiple cores
- The default output of event records is ProMC file format
The following HEP libraries are supported:
- CERNLIBlite - a light version of CERNLIB (without HBOOK)
- fastjet
- hepmc
- lhapdf5
- lhapdf6
- mcfm - MCFM NLO program with ProMC output ntuples
- jetphox - A JetPhox NLO program
- promc
- protobuf
- pythia8 - Pythia8 with ProMC output ntuples
- zlib
To setup the library, run this setup script:
source /home/chakanau/public/BG-HEP/bghep_setup.sh
This will setup the above libraries. Each library has a “Makefile” which can compile and run a program on BlueGene/Q
— Sergei Chekanov 2014/02/04 10:24
hpc/bghep/manual.1391539318.txt.gz · Last modified: 2014/02/04 18:41 by asc
