User Tools
Site Tools
hpc:bghep:manual
BG-HEP manual
(S.Chekanov, E.May)
BG-HEP library
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of Argonne Leadership Computing Facility. The main features of the BG-HEP library are:
  • Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls
  • Monte Carlo / NLO programs redesigned to use MPI for random seeds and outputs on multiple cores
  • The default output of event records is ProMC file format
The following HEP libraries are supported:
  • CERNLIBlite - a light version of CERNLIB (without HBOOK)
  • fastjet
  • hepmc
  • lhapdf5
  • lhapdf6
  • mcfm - MCFM NLO program with ProMC output ntuples
  • jetphox - A JetPhox NLO program
  • promc
  • protobuf
  • pythia8 - Pythia8 with ProMC output ntuples
  • zlib
To setup the library, run this setup script:
source /home/chakanau/public/BG-HEP/bghep_setup.sh
This will setup the above libraries. Each library has a “Makefile” which can compile and run a program on BlueGene/Q
<< back
Sergei Chekanov 2014/02/04 10:24
hpc/bghep/manual.1391539333.txt.gz · Last modified: 2014/02/04 18:42 by asc
