hpc:bghep:manual
BG-HEPlib manual
(S.Chekanov, E.May)
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of Argonne Leadership Computing Facility. The main features of the BG-HEP library are:
- Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls
- Monte Carlo / NLO programs redesigned to use MPI for random seeds and outputs on multiple cores
- The default output of event records is ProMC file format
The following HEP libraries are supported:
- CERNLIBlite - a light version of CERNLIB (without HBOOK)
- fastjet (v 3.03)
- hepmc (v 2.06.09)
- lhapdf5 (v5.9)
- lhapdf6 (v6.4)
- mcfm - (v6.7) MCFM NLO program with ProMC output ntuples
- jetphox (v3.02) - A JetPhox NLO program
- promc (v1.3)
- protobuf (v2.5)
- pythia8 (v8180)- Pythia8 with ProMC output ntuples
- zlib (v2.09)
To setup the library, run this setup script:
source /home/chakanau/public/BG-HEP/bghep_setup.sh
This will setup the above libraries. Each library has a “Makefile” which can compile and run a program on BlueGene/Q
— Sergei Chekanov 2014/02/04 10:24
hpc/bghep/manual.1391541977.txt.gz · Last modified: 2014/02/04 19:26 by asc
