hpc:hepmc
Table of Contents
HepMC Notes
Compiling on Edison@NERSC
After logging into a clean shell run
module unload altd module unload darshan module unload PrgEnv-intel module load PrgEnv-gnu module unload cray-shmem module load scons module load mercurial module load cmake module load boost module load gsl
Unpack HepMC tarball and enter HepMC main directory. Then Run
mkdir install ./bootstrap ./configure --with-pic --prefix=/path/to/sherpa/install --with-momentum=MEV --with-length=MM CC=cc CXX=CC --enable-shared=no make make install
Compiling on Tukey@ALCF
mkdir install ./configure --with-pic --prefix=$PWD/install --with-momentum=MEV --with-length=MM --enable-shared=no make make install
hpc/hepmc.txt · Last modified: 2015/01/14 16:26 by jchilders
