hpc:lcgcmake:cooleypatchfile
Cooley Patch File
- lcgcmake_cooley.patch
diff -Nwaur -x '*svn*' lcgcmake-unedited/cmake/toolchain/heptools-common.cmake lcgcmake/cmake/toolchain/heptools-common.cmake --- lcgcmake-unedited/cmake/toolchain/heptools-common.cmake 2015-08-24 19:02:28.232457227 +0000 +++ lcgcmake/cmake/toolchain/heptools-common.cmake 2015-08-21 13:32:39.029367379 +0000 @@ -72,9 +72,9 @@ set(os "cc") string(REGEX REPLACE ".*VERSION_ID=\"([0-9]+).*" "\\1" osvers "${os_release}") else() - message(WARNING "Unkown OS, assuming 'linux'") - set(os linux) - set(osvers) + message(WARNING "Unkown OS, assuming 'slc6'") + set(os "slc") + set(osvers 6) endif() endif() endif() diff -Nwaur -x '*svn*' lcgcmake-unedited/externals/CMakeLists.txt lcgcmake/externals/CMakeLists.txt --- lcgcmake-unedited/externals/CMakeLists.txt 2015-08-24 19:02:30.340232572 +0000 +++ lcgcmake/externals/CMakeLists.txt 2015-08-24 15:57:54.703229141 +0000 @@ -295,10 +295,12 @@ URL http://grid-deployment.web.cern.ch/grid-deployment/dms/lcgutil/tar/davix/davix-<NATIVE_VERSION>.tar.gz CONFIGURE_COMMAND ${CMAKE_COMMAND} -DCMAKE_INSTALL_PREFIX=<INSTALL_DIR> -DCMAKE_BUILD_TYPE=${CMAKE_BUILD_TYPE} - -DBOOST_ROOT:PATHNAME=${Boost_home} - -DBOOST_INCLUDEDIR=${Boost_home}/include - -DBOOST_LIBRARYDIR=${Boost_home}/lib - -DBoost_NO_BOOST_CMAKE=True + -DBoost_INCLUDE_DIR:PATH=${Boost_home}/include/boost-1_55 + -DBoost_LIBRARY_DIR_DEBUG:PATH=${Boost_home}/lib + -DBoost_LIBRARY_DIR_RELEASE:PATH=${Boost_home}/lib + -DBoost_NO_BOOST_CMAKE:BOOL=True + -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} + -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER} <SOURCE_DIR> DEPENDS Boost ) @@ -334,7 +336,7 @@ #set(hepmc3_source_command GIT_REPOSITORY https://:@git.cern.ch/kerberos/hepmc3) if( hepmc3_native_version MATCHES "githead") - set(hepmc3_source_command GIT_REPOSITORY http://git.cern.ch/cernpub/hepmc3) + set(hepmc3_source_command GIT_REPOSITORY http://git.cern.ch/pub/hepmc3) else() set(hepmc3_source_command URL http://service-spi.web.cern.ch/service-spi/external/tarFiles/MCGeneratorsTarFiles/hepmc3-${hepmc3_native_version}.tgz) endif() @@ -358,6 +360,8 @@ -DCMAKE_BUILD_TYPE=${CMAKE_BUILD_TYPE} -DHEPMC_BUILD_EXAMPLES=ON -DPYTHIA8_ROOT_DIR=${pythia8_home} + -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} + -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER} ${hepmc3_options} BUILD_COMMAND ${MAKE} -j1 DEPENDS ${hepmc3_dependencies} @@ -839,7 +843,7 @@ CMAKE_ARGS -DCMAKE_INSTALL_PREFIX=<INSTALL_DIR> -DUNWIND_INCLUDE_DIR:PATH=${libunwind_home}/include -DUNWIND_LIBRARY:FILEPATH=${libunwind_home}/lib/libunwind.so - "-DCMAKE_CXX_FLAGS=-Wno-unused-variable -Wno-error=unused-result" + "-DCMAKE_CXX_FLAGS=-Wno-unused-variable"# -Wno-error=unused-result" DEPENDS libunwind ) diff -Nwaur -x '*svn*' lcgcmake-unedited/generators/CMakeLists.txt lcgcmake/generators/CMakeLists.txt --- lcgcmake-unedited/generators/CMakeLists.txt 2015-08-24 19:02:35.483031899 +0000 +++ lcgcmake/generators/CMakeLists.txt 2015-08-21 01:39:32.500439326 +0000 @@ -1677,6 +1677,9 @@ URL ${gen_url}/crmc.v<NATIVE_VERSION>.tar.gz CMAKE_ARGS -DCMAKE_BUILD_TYPE=${CMAKE_BUILD_TYPE} -DCMAKE_INSTALL_PREFIX=<INSTALL_DIR> + -DCMAKE_MODULE_PATH=${CMAKE_SOURCE_DIR}/cmake/modules + -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} + -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER} -DROOTSYS=${ROOT_home} -DHEPMC_PREFIX=${HepMC_home} -DBOOST_ROOT=${Boost_home} diff -Nwaur -x '*svn*' lcgcmake-unedited/projects/CMakeLists.txt lcgcmake/projects/CMakeLists.txt --- lcgcmake-unedited/projects/CMakeLists.txt 2015-08-24 19:02:35.624216544 +0000 +++ lcgcmake/projects/CMakeLists.txt 2015-08-24 13:27:49.479842060 +0000 @@ -97,6 +97,8 @@ ${graphviz_home} ${GSL_home} ${Qt_home} ${CASTOR_home} ${dcap_home} CMAKE_ARGS -DCMAKE_BUILD_TYPE=${CMAKE_BUILD_TYPE} -DCMAKE_INSTALL_PREFIX=<INSTALL_DIR> + -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} + -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER} -Dpython=ON -Dbuiltin_pcre=ON -Dcintex=ON @@ -184,6 +186,8 @@ UPDATE_COMMAND <VOID> CMAKE_ARGS -DCMAKE_BUILD_TYPE=${CMAKE_BUILD_TYPE} -DCMAKE_INSTALL_PREFIX=<INSTALL_DIR> -DCMAKE_MODULE_PATH=${cmaketools_home}/modules + -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} + -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER} -DROOTSYS=${ROOT_home} # -DGCCXML=${GCCXML_home}/bin/gccxml IF DEFINED GCCXML_native_version THEN diff -Nwaur -x '*svn*' lcgcmake-unedited/toolchain.cmake lcgcmake/toolchain.cmake --- lcgcmake-unedited/toolchain.cmake 2015-08-24 19:02:35.670428000 +0000 +++ lcgcmake/toolchain.cmake 2015-08-21 01:12:00.031530000 +0000 @@ -1,5 +1,5 @@ # Special wrapper to load the declared version of the heptools toolchain. -set(LCG_VERSION dev2 CACHE STRING "HepTools version (aka LCG configuration)") +set(LCG_VERSION 78root6 CACHE STRING "HepTools version (aka LCG configuration)") # Remove the reference to this file from the cache. unset(CMAKE_TOOLCHAIN_FILE CACHE)
hpc/lcgcmake/cooleypatchfile.txt · Last modified: 2015/08/24 19:30 by jchilders
