hpc:pythia
Table of Contents
Building Pythia on BlueGene/Q
Part 1: Build HepMC Library
- Check out HepMC from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/HepMC-2.06.08 <destination_path>
- Inside the HepMC folder run
./bgq-make.sh
Part 2: Build Pythia Library
- Check out Pythia from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/v8180/bgq/trunk <destination_path>
- Inside the Pythia folder run
./bgq-make.sh
Part 3: Build Pythia Executable
- Check out TCLAP from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/tclap-1.2.1 <destination_path>
- Check out Pythia user code from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/usercode <destination_path>
- Inside the
usercode
folder you will find different programs written to use Pythia. As of this writting there was only one:alpToHepmc/runPythiaOnAlpgen.cpp
which can be used to shower Alpgen events and output HepMC format- There is a
Makefile
which can be used to make an executable, be sure to edit the paths inside theMakefile
to point to the HepMC/Pythia/TCLAP installations
Pythia Performance
On ''acinode.hep.anl.gov''
Hadronizing Alpgen events | ||||||
Z+Njets | N events | CPU Time (mm:ss) | Rate(Hz) | Accepted Events | Efficiency | Accepted Rate (Hz) |
Z+0jet | 14,062 | 12:34 | 18.6 | 10,000 | 71% | 13.2 |
Z+1jet | 25,340 | 21:45 | 19.4 | 10,000 | 39% | 7.6 |
Z+2jet | 41,834 | 36:26 | 19.1 | 10,000 | 23% | 4.5 |
Z+3jet | 26,549 | 23:50 | 18.5 | 3,587 | 13% | 2.5 |
Z+4jet |
<html><iframe width='500' height='300' frameborder='0' src='https://docs.google.com/spreadsheet/pub?key=0Aog5UiCGVmvRdDY5bGc0WTQxVXd5OUJMNVpTZ0JFRWc&single=true&gid=0&output=html&widget=true'></iframe></html>
hpc/pythia.1390341831.txt.gz · Last modified: 2014/01/21 22:03 by jchilders
