For now, use the IBM compiler. That requires ''compile.mk'' to have the following changes
ifeq ($(shell uname),Linux) # FFF = gfortran -fno-automatic # FF90 = gfortran -fno-automatic FFF = mpixlf77 -fno-automatic FF90 = mpixlf77 -fno-automatic #FFF = g77 -O1 -Wall -fno-automatic -Wno-globals -fno-backslash \ # -ffast-math endif
After a
make gen
or
make gen90
fails, one needs to do the following:
mpixlf77 -o wqqgen ./wqqusr.o ../wqqlib/wqq.o \ ../alplib/alpgen.o ../alplib/alputi.o ../alplib/alppdf.o \ ../alplib/Acp.o ../alplib/Asu3.o ../alplib/Aint.o
(or similar) to pass the linking phase.
Run on the command line:
soft add +mpiwrapper-xl
and change
compile.mk
to
ifeq ($(shell uname),Linux) # FFF = gfortran -fno-automatic # FF90 = gfortran -fno-automatic FFF = mpif77 -fno-automatic FF90 = mpif90 -fno-automatic #FFF = g77 -O1 -Wall -fno-automatic -Wno-globals -fno-backslash \ # -ffast-math endif
On line 182 of the file alplib/alpgen.f
change
access='append'
to position='append'
There's no getting around the bug by switching compilers on the Q. Replace asinh with argsinh whenever it appears:
can use this command: find . -exec grep -l “asinh” {} \; | xargs -I GGGG sh -c 'sed “s/asinh/argsinh/g” GGGG > GGGG.tmp; mv GGGG.tmp GGGG'
ran into error: ld: -f may not be used without -shared to fix it one needs to do the following:
Carver: Change compile.mk to have the following changes:
module swap pgi gcc module swap openmpi openmpi-gcc
Then everything is fine.
Hopper:
module swap PrgEnv-pgi PrgEnv-gnu
That requires compile.mk to have the following changes
FFF = ftn FF90 = ftn
Edison
module swap PrgEnv-intel PrgEnv-gnu
2) Deal with MPI
2.1) Add the lines
integer mpirank character*5 rankstring common/mpi/mpirank,rankstring
Just after the line “c common declarations” in subroutine alsdef in file alpgen.f It will be near line 209
2.2 Add the lines
C MPI variables
include 'mpif.h' integer rank, size, ierror, tag, status(MPI_STATUS_SIZE)
Just before the line “c list processes”. This will be near line 230
c beginning of MPI block
call MPI_INIT(ierror) call MPI_COMM_SIZE(MPI_COMM_WORLD, size, ierror) call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierror) mpirank = rank call MPI_FINALIZE(ierror) write(6,*) 'MPI finalized: rank ', mpirank write( rankstring, '(i5.5)' ) mpirank
c end of MPI block
2.3) Add the lines
c work in a unique directory ./work/rankstring
call chdir("work") call chdir(rankstring)
Immediately after the end of the MPI block
2.4) Just after the lines:
c save parameter values to relative variables in common blocks
call alspar
This will be near line 338:
Add the lines
iseed(1)=iseed(1)+mod(mpirank,65536) iseed(2)=iseed(2)+int(mpirank/65536) print*, 'Seeds and mpirank', iseed(1),iseed(2),mpirank
c end of MPI block
2.3 In subroutine alstio, just after include 'alpgen.inc' (near line 4584) add the lines:
2.3 In subroutine alstio, replace
call alustc(fname,'.wgt',tmpstr)
with
call alustc('../../'fname,'.'rankstring'.wgt',tmpstr) immediately after write(6,*) 'Run parameters and diagnostics written to ' $ ,tmpstr(1:l) Near line 4588. This outputs the weighted event files in a common directory 3) Replace unit 5 with unit 9 for input Near line 306, after C MANDATORY INPUTS add for BlueGene open(9,file='../../input.1',action='read') for Carver open(9,file='../../input.1',access='read') This reads the input configuration from file, instead of from the command line input via a redirect as in the tutorial Then replace all READ(5, with READ(9,
