(S.Chekanov, E.May)
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of Argonne Leadership Computing Facility. The main features of the BG@HEP library are:
The following HEP libraries are supported:
To setup the library, run this setup script:
source /home/chakanau/public/BG-HEP/bghep_setup.sh
This will setup the above libraries. Each library has a “Makefile” which can be compiled and run a program on BlueGene/Q. Look at this “bghep_setup.sh” to see location of each library.
A list of Monte Carlo simulations and NLO programs generated on BlueGene/Q (Vesta, ANL) is listed on the RefHepSim web page.
— Sergei Chekanov 2014/02/04 10:24
