svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/HepMC-2.06.08 <destination_path>
./bgq-make.sh
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/v8180/bgq/trunk <destination_path>
./bgq-make.sh
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/tclap-1.2.1 <destination_path>
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/usercode <destination_path>
usercode
folder you will find different programs written to use Pythia. As of this writting there was only one:alpToHepmc/runPythiaOnAlpgen.cpp
which can be used to shower Alpgen events and output HepMC formatMakefile
which can be used to make an executable, be sure to edit the paths inside the Makefile
to point to the HepMC/Pythia/TCLAP installationsHadronizing Alpgen events | ||||||
Z+Njets | N events | CPU Time (mm:ss) | Rate(Hz) | Accepted Events | Efficiency | Accepted Rate (Hz) |
Z+0jet | 14,062 | 12:34 | 18.6 | 10,000 | 71% | 13.2 |
Z+1jet | 25,340 | 21:45 | 19.4 | 10,000 | 39% | 7.6 |
Z+2jet | 41,834 | 36:26 | 19.1 | 10,000 | 23% | 4.5 |
Z+3jet | 26,549 | 23:50 | 18.5 | 3,587 | 13% | 2.5 |
Z+4jet |
<iframe width='500' height='300' frameborder='0' src='https://docs.google.com/spreadsheet/pub?key=0Aog5UiCGVmvRdDY5bGc0WTQxVXd5OUJMNVpTZ0JFRWc&single=true&gid=0&output=html&widget=true'></iframe>
