User Tools
Site Tools
hpc:pythia
Building Pythia on BlueGene/Q
Part 1: Build HepMC Library
  1. Check out HepMC from SVN:
    svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/HepMC-2.06.08 <destination_path>
  2. Inside the HepMC folder run
    ./bgq-make.sh
Part 2: Build Pythia Library
  1. Check out Pythia from SVN:
    svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/v8180/bgq/trunk <destination_path>
  2. Inside the Pythia folder run
    ./bgq-make.sh
Part 3: Build Pythia Executable
  1. Check out TCLAP from SVN:
    svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/tclap-1.2.1 <destination_path>
  2. Check out Pythia user code from SVN:
    svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/usercode <destination_path>
  3. Inside the usercode folder you will find different programs written to use Pythia. As of this writting there was only one:
    • alpToHepmc/runPythiaOnAlpgen.cpp which can be used to shower Alpgen events and output HepMC format
      • There is a Makefile which can be used to make an executable, be sure to edit the paths inside the Makefile to point to the HepMC/Pythia/TCLAP installations
Pythia Performance
On ''acinode.hep.anl.gov''
hpc/pythia.1390342670.txt.gz · Last modified: 2014/01/21 22:17 by jchilders
