[ {rabbit, [ {ssl_listeners, [5671]}, {ssl_options, [{cacertfile,"/path/to/testca/cacert.pem"}, {certfile,"/path/to/server/cert.pem"}, {keyfile,"/path/to/server/key.pem"}, {verify,verify_peer}, {fail_if_no_peer_cert,true}]} ]} ].
#!/usr/bin/env python import pika import sys,ssl # Setup our ssl options ssl_options = {"ca_certs": "/path/to/testca/cacert.pem", "certfile": "/path/to/client/cert.pem", "keyfile": "/path/to/client/key.pem", "cert_reqs": ssl.CERT_REQUIRED, } connection = pika.BlockingConnection(pika.ConnectionParameters(host='servername.com',port=5671,ssl=True,ssl_options=ssl_options)) channel = connection.channel() channel.queue_declare(queue='hello') channel.basic_publish(exchange='', routing_key='hello', body='Hello World!') print " [x] Sent 'Hello World!'" connection.close()
