<html xmlns=“http://www.w3.org/1999/xhtml” xml:lang=“en” lang=“en”><head><meta http-equiv=“Content-type” content=“text/html;charset=utf-8”><link rel=“stylesheet” href=“https://gantter.smartapp.com/css/styles.css” type=“text/css” media=“screen,projection,print”><link rel=“stylesheet” href=“https://gantter.smartapp.com/css/print.css” type=“text/css” media=“screen,projection,print”></head><body><h1>HPC.ganttChart</h1><div id=“list” style=“position:relative;”><table id=“tasks”><thead><tr><th class=“ds” style=“width: 47px;”> </th><th class=“dg” style=“width: 60px; display: none;”>WBS</th><th class=“dh” style=“width: 18px;”><div class=“dr”></div></th><th class=“di” style=“width: 358px;”>Name</th><th class=“dj” style=“width: 67px;”>Duration</th><th class=“dk” style=“width: 65px; display: none;”>Work</th><th class=“dl” style=“width: 60px; display: none;”>Cost</th><th class=“dm” style=“width: 90px; display: none;”>% Complete</th><th class=“dn” style=“width: 72px;”>Start</th><th class=“do” style=“width: 71px;”>Finish</th><th class=“dp” style=“width: 56px;”>Predecessors</th><th class=“dq” style=“width: 211px;”>Resources</th><th class=“pU” style=“width: 70px; display: none;”>Baseline <br>Start Date</th><th class=“pV” style=“width: 70px; display: none;”>Baseline <br>Finish Date</th><th class=“pW” style=“width: 60px; display: none;”>Baseline <br>Cost</th><th class=“pX” style=“width: 65px; display: none;”>Baseline <br>Work</th><th class=“pY” style=“width: 65px; display: none;”>Baseline <br>Duration</th></tr></thead><tbody><tr style=“display:none” class=“dH”><td title=“0” class=“ds”>0</td><td title=“0” style=“display: none;” class=“dg”>0</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“0”></div><div class=“mM ja” style=“display: none;” tag=“0”></div><div class=“mM jb” style=“display: none;” tag=“0”></div><div class=“mM jc” style=“display: none;” tag=“0”></div><div class=“mM jd” style=“display: none;” tag=“0”></div><div class=“mM je” style=“display: none;” tag=“0”></div><div class=“mM lc” style=“display: none;” tag=“0”></div><div class=“mM qC” style=“display: none;” tag=“0”></div> </div></td><td style=“padding-left: 0px” class=“di”><div class=“collapse”></div><div class=“ri”>HPC.ganttChart</div></td><td class=“dj”><div class=“ri”>75d?</div></td><td class=“dk” style=“display: none;”><div class=“ri”>460.8h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/06/2014" class="dn">01/06/2014</td><td title="04/18/2014" class="do">04/18/2014</td><td class="dp"> </td><td class="dq"> </td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr class="dH"><td title="1" class="ds">1</td><td title="1" style="display: none;" class="dg">1</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="1"></div><div class="mM ja" style="display: none;" tag="1"></div><div class="mM jb" style="display: none;" tag="1"></div><div class="mM jc" style="display: none;" tag="1"></div><div class="mM jd" style="display: none;" tag="1"></div><div class="mM je" style="display: none;" tag="1"></div><div class="mM lc" style="display: none;" tag="1"></div><div class="mM qC" style="display: none;" tag="1"></div> </div></td><td style="padding-left: 0px" class="di"><div class="collapse"></div><div class="ri">Balsam Development</div></td><td class="dj"><div class="ri">15d</div></td><td class="dk" style="display: none;"><div class="ri">148.8h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/06/2014” class=“dn”>01/06/2014</td><td title=“01/27/2014” class=“do”>01/27/2014</td><td class=“dp”> </td><td class=“dq”> </td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“2” class=“ds”>2</td><td title=“1.1” style=“display: none;” class=“dg”>1.1</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“2”></div><div class=“mM ja” style=“display: none;” tag=“2”></div><div class=“mM jb” style=“display: none;” tag=“2”></div><div class=“mM jc” style=“display: none;” tag=“2”></div><div class=“mM jd” style=“display: none;” tag=“2”></div><div class=“mM je” tag=“2”></div><div class=“mM lc” style=“display: none;” tag=“2”></div><div class=“mM qC” style=“display: none;” tag=“2”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Port to Condor</div></td><td class=“dj”><div class=“ri”>10d</div></td><td class=“dk” style=“display: none;”><div class=“ri”>96h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/06/2014" class="dn">01/06/2014</td><td title="01/17/2014" class="do">01/17/2014</td><td class="dp"> </td><td class="dq">Taylor Childers,Tom Uram[20%]</td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr><td title="3" class="ds">3</td><td title="1.2" style="display: none;" class="dg">1.2</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="3"></div><div class="mM ja" style="display: none;" tag="3"></div><div class="mM jb" style="display: none;" tag="3"></div><div class="mM jc" style="display: none;" tag="3"></div><div class="mM jd" style="display: none;" tag="3"></div><div class="mM je" tag="3"></div><div class="mM lc" style="display: none;" tag="3"></div><div class="mM qC" style="display: none;" tag="3"></div> </div></td><td style="padding-left: 20px" class="di"><div class="ri">Test with Cobalt</div></td><td class="dj"><div class="ri">3d</div></td><td class="dk" style="display: none;"><div class="ri">28.8h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/20/2014” class=“dn”>01/20/2014</td><td title=“01/22/2014” class=“do”>01/22/2014</td><td class=“dp”>2</td><td class=“dq”>Taylor Childers,Tom Uram[20%]</td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“4” class=“ds”>4</td><td title=“1.3” style=“display: none;” class=“dg”>1.3</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“4”></div><div class=“mM ja” style=“display: none;” tag=“4”></div><div class=“mM jb” style=“display: none;” tag=“4”></div><div class=“mM jc” style=“display: none;” tag=“4”></div><div class=“mM jd” style=“display: none;” tag=“4”></div><div class=“mM je” style=“display: none;” tag=“4”></div><div class=“mM lc” style=“display: none;” tag=“4”></div><div class=“mM qC” style=“display: none;” tag=“4”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Port to Torque(NERSC)</div></td><td class=“dj”><div class=“ri”>15d</div></td><td class=“dk” style=“display: none;”><div class=“ri”>24h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/06/2014" class="dn">01/06/2014</td><td title="01/27/2014" class="do">01/27/2014</td><td class="dp"> </td><td class="dq">Tom Uram[20%]</td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr class="dH"><td title="5" class="ds">5</td><td title="2" style="display: none;" class="dg">2</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="5"></div><div class="mM ja" style="display: none;" tag="5"></div><div class="mM jb" style="display: none;" tag="5"></div><div class="mM jc" style="display: none;" tag="5"></div><div class="mM jd" style="display: none;" tag="5"></div><div class="mM je" style="display: none;" tag="5"></div><div class="mM lc" style="display: none;" tag="5"></div><div class="mM qC" style="display: none;" tag="5"></div> </div></td><td style="padding-left: 0px" class="di"><div class="collapse"></div><div class="ri">Run Pythia8 Jobs</div></td><td class="dj"><div class="ri">23d</div></td><td class="dk" style="display: none;"><div class="ri">264h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/17/2014” class=“dn”>01/17/2014</td><td title=“02/18/2014” class=“do”>02/18/2014</td><td class=“dp”> </td><td class=“dq”> </td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“6” class=“ds”>6</td><td title=“2.1” style=“display: none;” class=“dg”>2.1</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“6”></div><div class=“mM ja” style=“display: none;” tag=“6”></div><div class=“mM jb” tag=“6”></div><div class=“mM jc” style=“display: none;” tag=“6”></div><div class=“mM jd” style=“display: none;” tag=“6”></div><div class=“mM je” tag=“6”></div><div class=“mM lc” style=“display: none;” tag=“6”></div><div class=“mM qC” style=“display: none;” tag=“6”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Create Pythia job script</div></td><td class=“dj”><div class=“ri”>10d</div></td><td class=“dk” style=“display: none;”><div class=“ri”>80h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/17/2014" class="dn">01/17/2014</td><td title="01/30/2014" class="do">01/30/2014</td><td class="dp"> </td><td class="dq">Taylor Childers</td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr><td title="7" class="ds">7</td><td title="2.2" style="display: none;" class="dg">2.2</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="7"></div><div class="mM ja" style="display: none;" tag="7"></div><div class="mM jb" style="display: none;" tag="7"></div><div class="mM jc" style="display: none;" tag="7"></div><div class="mM jd" style="display: none;" tag="7"></div><div class="mM je" tag="7"></div><div class="mM lc" style="display: none;" tag="7"></div><div class="mM qC" style="display: none;" tag="7"></div> </div></td><td style="padding-left: 20px" class="di"><div class="ri">Setup Pythia8 on Vesta</div></td><td class="dj"><div class="ri">3d</div></td><td class="dk" style="display: none;"><div class="ri">24h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/31/2014” class=“dn”>01/31/2014</td><td title=“02/04/2014” class=“do”>02/04/2014</td><td class=“dp”>6</td><td class=“dq”>Taylor Childers</td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“8” class=“ds”>8</td><td title=“2.3” style=“display: none;” class=“dg”>2.3</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“8”></div><div class=“mM ja” style=“display: none;” tag=“8”></div><div class=“mM jb” style=“display: none;” tag=“8”></div><div class=“mM jc” style=“display: none;” tag=“8”></div><div class=“mM jd” style=“display: none;” tag=“8”></div><div class=“mM je” tag=“8”></div><div class=“mM lc” style=“display: none;” tag=“8”></div><div class=“mM qC” style=“display: none;” tag=“8”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Develop shared file protocol in MPI</div></td><td class=“dj”><div class=“ri”>10d</div></td><td class=“dk” style=“display: none;”><div class=“ri”>160h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="02/05/2014" class="dn">02/05/2014</td><td title="02/18/2014" class="do">02/18/2014</td><td class="dp">7</td><td class="dq">Taylor Childers,Tom Uram</td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr style="font-weight:bold;" class="dH"><td title="9" class="ds">9</td><td title="3" style="display: none;" class="dg">3</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="9"></div><div class="mM ja" style="display: none;" tag="9"></div><div class="mM jb" style="display: none;" tag="9"></div><div class="mM jc" style="display: none;" tag="9"></div><div class="mM jd" style="display: none;" tag="9"></div><div class="mM je" style="display: none;" tag="9"></div><div class="mM lc" style="display: none;" tag="9"></div><div class="mM qC" style="display: none;" tag="9"></div> </div></td><td style="padding-left: 0px" class="di"><div class="collapse"></div><div class="ri">New Pilot Job Development</div></td><td class="dj"><div class="ri">60d</div></td><td class="dk" style="display: none;"><div class="ri">48h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/27/2014” class=“dn”>01/27/2014</td><td title=“04/18/2014” class=“do”>04/18/2014</td><td class=“dp”> </td><td class=“dq”> </td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“10” class=“ds”>10</td><td title=“3.1” style=“display: none;” class=“dg”>3.1</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“10”></div><div class=“mM ja” style=“display: none;” tag=“10”></div><div class=“mM jb” tag=“10”></div><div class=“mM jc” style=“display: none;” tag=“10”></div><div class=“mM jd” style=“display: none;” tag=“10”></div><div class=“mM je” style=“display: none;” tag=“10”></div><div class=“mM lc” style=“display: none;” tag=“10”></div><div class=“mM qC” style=“display: none;” tag=“10”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Study Danilla's Example</div></td><td class=“dj”><div class=“ri”>60d</div></td><td class=“dk” style=“display: none;”><div class=“ri”>48h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/27/2014" class="dn">01/27/2014</td><td title="04/18/2014" class="do">04/18/2014</td><td class="dp"> </td><td class="dq">Doug Benjamin[10%]</td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr class="dH"><td title="11" class="ds">11</td><td title="4" style="display: none;" class="dg">4</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="11"></div><div class="mM ja" style="display: none;" tag="11"></div><div class="mM jb" style="display: none;" tag="11"></div><div class="mM jc" style="display: none;" tag="11"></div><div class="mM jd" style="display: none;" tag="11"></div><div class="mM je" style="display: none;" tag="11"></div><div class="mM lc" style="display: none;" tag="11"></div><div class="mM qC" style="display: none;" tag="11"></div> </div></td><td style="padding-left: 0px" class="di"><div class="collapse"></div><div class="ri">RabbitMQ Development</div></td><td class="dj"><div class="ri">1d?</div></td><td class="dk" style="display: none;"><div class="ri">0h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/06/2014” class=“dn”>01/06/2014</td><td title=“01/06/2014” class=“do”>01/06/2014</td><td class=“dp”> </td><td class=“dq”> </td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr><tr><td title=“12” class=“ds”>12</td><td title=“4.1” style=“display: none;” class=“dg”>4.1</td><td class=“dh”><div class=“lb”><div class=“mM iZ” style=“display: none;” tag=“12”></div><div class=“mM ja” style=“display: none;” tag=“12”></div><div class=“mM jb” style=“display: none;” tag=“12”></div><div class=“mM jc” style=“display: none;” tag=“12”></div><div class=“mM jd” style=“display: none;” tag=“12”></div><div class=“mM je” style=“display: none;” tag=“12”></div><div class=“mM lc” style=“display: none;” tag=“12”></div><div class=“mM qC” style=“display: none;” tag=“12”></div> </div></td><td style=“padding-left: 20px” class=“di”><div class=“ri”>Implement SSL Handshaking</div></td><td class=“dj”><div class=“ri”>1d?</div></td><td class=“dk” style=“display: none;”><div class=“ri”>0h</div></td><td class=“dl” style=“display: none;”><div class=“ri”>$0</div></td><td class="dm" style="display: none;"><div class="ri">0%</div></td><td title="01/06/2014" class="dn">01/06/2014</td><td title="01/06/2014" class="do">01/06/2014</td><td class="dp"> </td><td class="dq"> </td><td title="" class="pU" style="display: none;">NA</td><td title="" class="pV" style="display: none;">NA</td><td title="" class="pW" style="display: none;"></td><td title="" class="pX" style="display: none;"></td><td title="" class="pY" style="display: none;"></td></tr><tr><td title="13" class="ds">13</td><td title="4.2" style="display: none;" class="dg">4.2</td><td class="dh"><div class="lb"><div class="mM iZ" style="display: none;" tag="13"></div><div class="mM ja" style="display: none;" tag="13"></div><div class="mM jb" style="display: none;" tag="13"></div><div class="mM jc" style="display: none;" tag="13"></div><div class="mM jd" style="display: none;" tag="13"></div><div class="mM je" style="display: none;" tag="13"></div><div class="mM lc" style="display: none;" tag="13"></div><div class="mM qC" style="display: none;" tag="13"></div> </div></td><td style="padding-left: 20px" class="di"><div class="ri">Write user/Balsam library</div></td><td class="dj"><div class="ri">1d?</div></td><td class="dk" style="display: none;"><div class="ri">0h</div></td><td class="dl" style="display: none;"><div class="ri">$0</div></td><td class=“dm” style=“display: none;”><div class=“ri”>0%</div></td><td title=“01/06/2014” class=“dn”>01/06/2014</td><td title=“01/06/2014” class=“do”>01/06/2014</td><td class=“dp”> </td><td class=“dq”> </td><td title=“” class=“pU” style=“display: none;”>NA</td><td title=“” class=“pV” style=“display: none;”>NA</td><td title=“” class=“pW” style=“display: none;”></td><td title=“” class=“pX” style=“display: none;”></td><td title=“” class=“pY” style=“display: none;”></td></tr></tbody></table></div><br><div id=“chart” style=“position:relative;”><div id=“mc”><table id=“gantt” style=“width:2975px”><thead><tr><th colspan=“7”>Dec 29 - Jan 4 '14</th><th colspan=“7”>Jan 5 - Jan 11 '14</th><th colspan=“7”>Jan 12 - Jan 18 '14</th><th colspan=“7”>Jan 19 - Jan 25 '14</th><th colspan=“7”>Jan 26 - Feb 1 '14</th><th colspan=“7”>Feb 2 - Feb 8 '14</th><th colspan=“7”>Feb 9 - Feb 15 '14</th><th colspan=“7”>Feb 16 - Feb 22 '14</th><th colspan=“7”>Feb 23 - Mar 1 '14</th><th colspan=“7”>Mar 2 - Mar 8 '14</th><th colspan=“7”>Mar 9 - Mar 15 '14</th><th colspan=“7”>Mar 16 - Mar 22 '14</th><th colspan=“7”>Mar 23 - Mar 29 '14</th><th colspan=“7”>Mar 30 - Apr 5 '14</th><th colspan=“7”>Apr 6 - Apr 12 '14</th><th colspan=“7”>Apr 13 - Apr 19 '14</th><th colspan=“7”>Apr 20 - Apr 26 '14</th></tr><tr><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th><th>S</th><th>M</th><th>T</th><th>W</th><th>T</th><th>F</th><th>S</th></tr></thead><tbody><tr style=“height: 312px;”><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td><td class=“off” colspan=“1”> </td><td colspan=“5”> </td><td class=“off end” colspan=“1”> </td></tr></tbody></table><div class=“lk”> </div><div class=“iT mM” tag=“1” style=“top:42px;left:208px;width:525px”><div class=“iU”></div><div class=“iV”></div><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:43px;left:739px”></div><div class=“task mM” tag=“2” style=“top:66px;left:208px;width:284px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:67px;left:498px”>Taylor Childers,Tom Uram[20%]</div><div class=“task mM” tag=“3” style=“top:90px;left:558px;width:59px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:91px;left:623px”>Taylor Childers,Tom Uram[20%]</div><div class=“task mM” tag=“4” style=“top:114px;left:208px;width:525px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:115px;left:739px”>Tom Uram[20%]</div><div class=“iT mM” tag=“5” style=“top:138px;left:483px;width:809px”><div class=“iU”></div><div class=“iV”></div><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:139px;left:1298px”></div><div class=“task mM” tag=“6” style=“top:162px;left:483px;width:334px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:163px;left:823px”>Taylor Childers</div><div class=“task mM” tag=“7” style=“top:186px;left:833px;width:109px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:187px;left:948px”>Taylor Childers</div><div class=“task mM” tag=“8” style=“top:210px;left:958px;width:334px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:211px;left:1298px”>Taylor Childers,Tom Uram</div><div class=“iT mM” tag=“9” style=“top:234px;left:733px;width:2035px”><div class=“iU”></div><div class=“iV”></div><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:235px;left:2774px”></div><div class=“task mM” tag=“10” style=“top:258px;left:733px;width:2035px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:259px;left:2774px”>Doug Benjamin[10%]</div><div class=“iT mM” tag=“11” style=“top:282px;left:208px;width:9px”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:283px;left:223px”></div><div class=“task mM” tag=“12” style=“top:306px;left:208px;width:9px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:307px;left:223px”></div><div class=“task mM” tag=“13” style=“top:330px;left:208px;width:9px;”><div class=“iS” style=“width:0%”></div></div><div class=“iW” style=“top:331px;left:223px”></div><div class=“line” style=“left:492px;top:76px;width:5px;height:1px”></div><div class=“line” style=“left:496px;top:76px;width:1px;height:25px”></div><div class=“line” style=“left:496px;top:100px;width:63px;height:1px”></div><div class=“js” style=“left:554px;top:97px”></div><div class=“line” style=“left:817px;top:172px;width:5px;height:1px”></div><div class=“line” style=“left:821px;top:172px;width:1px;height:25px”></div><div class=“line” style=“left:821px;top:196px;width:13px;height:1px”></div><div class=“js” style=“left:829px;top:193px”></div><div class=“line” style=“left:942px;top:196px;width:5px;height:1px”></div><div class=“line” style=“left:946px;top:196px;width:1px;height:25px”></div><div class=“line” style=“left:946px;top:220px;width:13px;height:1px”></div><div class=“js” style=“left:954px;top:217px”></div><div class=“iX” style=“top: 42px; left: 574px; height: 312px;”></div></div></div></body></html>
