wget http://www.hepforge.org/archive/sherpa/SHERPA-MC-2.1.1.tar.gz
In most cases opening Makefile
and commenting out line 470/471 which have the words Manual
and Examples
on it will save you some time.
«< I frequently have to do 'autoreconf' before 'make' when doing a fresh install. Not sure why, just do. »>
makelibs
compile script and many other Makefiles.in
in the Process
subdirectory that has full absolute path inside that points to the local Sherpa installation. Many of the configure*
and automake
files contain absolute paths to the directory in which the code generation step was executed. This causes problems if one tries to move the code generation to another system or folder.Install HepMC.
After logging into a clean shell run
module unload altd module unload darshan module unload PrgEnv-intel module load PrgEnv-gnu module unload cray-shmem module load scons module load mercurial module load cmake module load boost module load gsl
Unpack Sherpa tarball and enter sherpa main directory. Then comment out line 470 of the Makefile for Sherpa which has the word “Manual” on it. You can create a mostly-static or dynamic executable by using the '-static' and '–enable-static=yes', or '-dynamic' flags, respectively. Then run: <WRAP prewrap>
mkdir install ./configure --enable-mpi --enable-gzip --with-sqlite3=/global/project/projectdirs/m2015/generators/sherpa/v211/sherpa-02-01-00/sqlite-autoconf-3080200/install --enable-hepmc2=/global/project/projectdirs/m2015/tools/HepMC-2.06.08/install --enable-openloops=/project/projectdirs/m2015/olo/mpi CC=cc CXX=CC FC='ftn -fPIC -funderscoring' LDFLAGS=-dynamic --prefix=$PWD/install make -j 10 make install
</WRAP>
If you go for the static flags the make will fail just before the executable is built so then do this:
<WRAP prewrap>
./configure --enable-mpi --enable-hepmc2=/project/projectdirs/m2015/tools/HepMC-2.06.08/local/ --with-pic LDFLAGS=-static MPICXX=CC CC=cc CXX=CC --prefix=$PWD/install --enable-openloops=/project/projectdirs/m2015/tools/OpenLoops/ --enable-gzip --enable-static=yes --enable-shared=yes make -j 10 make -j 10 install cd SHERPA/Run ../../libtool --tag=CXX --mode=link CC -Wl,--no-as-needed -g -O2 -rdynamic -Wl,--no-as-needed -o Sherpa ../../*/*/*.o ../../*/*/*/*.o /project/projectdirs/m2015/tools/HepMC-2.06.08/src/*.o -lgfortran /usr/lib64/libz.a -lsqlite3 > libtool.log # this will fail with errors then run this sed s/"libtool: link: "//g libtool.log | sed s/"..\/..\/PDF\/CT10\/CT10_Fortran_Interface.o"//g | sed s/"..\/..\/PDF\/CT10\/CT10Pdf.o "//g | sed s/"..\/..\/PDF\/CT10\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12Pdf.o "//g | sed s/"..\/..\/PDF\/CT12\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CTEQ\/CTEQ6_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CTEQ\/Cteq6Pdf-2008.o "//g | sed s/"..\/..\/PDF\/CTEQ\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/Electron\/PDF_Electron.o "//g | sed s/"..\/..\/PDF\/Electron\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/GRV\/GRVph_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/GRV\/grvphoton.o "//g | sed s/"..\/..\/PDF\/GRV\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2001lo.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2004qed.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst99.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST01LO.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST04QED.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST99.o "//g | sed s/"..\/..\/PDF\/MRST\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MSTW\/mstwpdf.o "//g | sed s/"..\/..\/PDF\/MSTW\/PDF_MSTW.o "//g | sed s/"..\/..\/PDF\/MSTW\/SVN_Info.o "//g | sed s/"\/opt\/gcc\/4.9.2\/snos\/lib\/..\/lib64\/libquadmath.so"/"-lquadmath"/g | sed s/"\/opt\/gcc\/4.9.2\/snos\/lib\/..\/lib64\/libgfortran.so"/"-lgfortran"/g | sed s/"\/usr\/lib64\/libsqlite3.so"/"-lsqlite3"/g > compile_Sherpa.sh sh compile_Sherpa.sh cp Sherpa ../../install/bin/
</WRAP>
Examples/test
. Run.dat
and fill it with this text: (run){ % general setting EVENTS 1; ERROR 0.99; EVENT_OUTPUT=HEPEVT[specialtest]; % scales, tags for scale variations SP_NLOCT 1; FSF:=1.; RSF:=1.; QSF:=1.; SCALES METS{FSF*MU_F2}{RSF*MU_R2}{QSF*MU_Q2}; % tags for process setup NJET:=2; LJET:=2; QCUT:=20.; % me generator settings ME_SIGNAL_GENERATOR Comix Amegic LOOPGEN; EVENT_GENERATION_MODE Weighted; LOOPGEN:=Internal; % exclude tau from lepton container MASSIVE[15] 1; % collider setup BEAM_1 2212; BEAM_ENERGY_1 = 4000.; BEAM_2 2212; BEAM_ENERGY_2 = 4000.; }(run) (processes){ Process 93 93 -> 90 91 93{NJET}; Order_EW 2; CKKW sqr(QCUT/E_CMS); NLO_QCD_Mode MC@NLO {LJET}; ME_Generator Amegic {LJET}; Loop_Generator LOOPGEN {LJET}; Scales LOOSE_METS{FSF*MU_F2}{RSF*MU_R2}{QSF*MU_Q2} {7,8}; End process; }(processes) (selector){ Mass 11 -12 5. E_CMS Mass 13 -14 5. E_CMS Mass -11 12 5. E_CMS Mass -13 14 5. E_CMS }(selector) }(run)
qsub -I -q default -l mppwidth=24
cd $PBS_O_WORKDIR
. aprun -n 1 -N 1 ../../install/bin/Sherpa
./makelibs
soft add +mvapich2
soft add +gcc-4.8.1
mkdir install ./configure --enable-gzip --enable-openloops=/projects/EnergyFEC/anl/cooley/tools/OpenLoops-r1354 --enable-hepmc2=/projects/EnergyFEC/anl/cooley/tools/HepMC-2.06.09/install --with-sqlite3=/projects/EnergyFEC/anl/cooley/tools/sqlite-autoconf-3080200/install --enable-mpi --enable-static=yes --prefix=$PWD/install
</WRAP>
Makefile
remove line 472 because tukey doesn't have the 'texi2html' app installed needed to compile the manual.SUBDIRS = \ ATOOLS \ BEAM \ PDF \ MODEL \ METOOLS \ PHASIC++ \ MCATNLO \ EXTRA_XS \ AMEGIC++ \ COMIX \ CSSHOWER++ \ AMISIC++ \ AHADIC++ \ HADRONS++ \ PHOTONS++ \ SHRiMPS \ SHERPA \ AddOns \ Manual \ # <---- this line Examples
make make install
/path/to/OpenLoops/scons-local
. Scons is used to compile the process libraries, the code for which is written when you first call Sherpa with your run card. If you don't have scons, it tries to use autoconfig
which can have difficulties sometimes whereas Scons does not. wget http://prdownloads.sourceforge.net/scons/scons-2.3.4.tar.gz # Unpack tarball and enter main scons directory mkdir install python setup.py install --prefix=$PWD/install export PATH=$PATH:$PWD/install/bin
soft add +mpiwrapper-gcc svn export svn+ssh://atlas1.hep.anl.gov/users/svn/hpc/generators/sherpa/v211/bgq/tags/03-00-00 sherpa-03-00-00 cd sherpa-03-00-00 ./configure --enable-mpi --with-pic --enable-gzip=/soft/libraries/alcf/current/gcc/ZLIB --enable-openloops=/projects/EnergyFEC/anl/ol-mpi --with-sqlite3=/projects/EnergyFEC/general_tools/sqlite-autoconf-3080200/install --enable-hepmc2=/projects/EnergyFEC/general_tools/HepMC-2.06.09/install --host=powerpc64-bgq-linux CC=mpicc CFLAGS=-g CPPFLAGS=-g CXXFLAGS=-g MPICXX=mpicxx CXX=mpicxx FC='mpif90 -fPIC -funderscoring' FCFLAGS=-g LDFLAGS=-dynamic --prefix=$PWD/install host_alias=powerpc64-bgq-linux make -j 20 install
</WRAP>
<WRAP prewrap>
svn export svn+ssh://atlas1.hep.anl.gov/users/svn/hpc/generators/sherpa/v211/bgq/tags/02-01-00 sherpa-02-01-00 ./configure --host=powerpc64-unknown-linux-gnu --with-sqlite3=install --enable-gzip=/soft/libraries/alcf/current/gcc/ZLIB --enable-openloops=/projects/ATLASQ/ol-mpi --enable-hepmc2=/home/projects/ATLASQ/tools/HepMC-2.06.08/install --enable-mpi --enable-shared=yes --prefix=$PWD/install --with-pic CC=mpicc CFLAGS=-pg LDFLAGS=-pg CPPFLAGS=-pg FC=mpif90 FCFLAGS=-pg MPICXX=mpicxx CXX=mpicxx CXXFLAGS=-pg
</WRAP> This step will fail because it cannot compile sqlite3 without some help. So go in the sqlite3 directory and run the following. <WRAP prewrap>
mkdir install ./configure --enable-static=yes --prefix=$PWD/install make make install
</WRAP> Then move back to Sherpa root path and rerun the configure step. <WRAP prewrap>
./configure --host=ppc64 --enable-gzip=/soft/libraries/alcf/current/gcc/ZLIB --enable-openloops=/projects/ATLASQ/ol-mpi --enable-hepmc2=/home/projects/ATLASQ/tools/HepMC-2.06.08/install --enable-mpi --enable-shared=yes --prefix=$PWD/install --with-pic CC=mpicc CFLAGS=-pg LDFLAGS=-pg CPPFLAGS=-pg FC=mpif90 FCFLAGS=-pg MPICXX=mpicxx CXX=mpicxx CXXFLAGS=-pg make V=1 -j 10 > make.log 2>&1 & make -j 10 install
</WRAP>
For static build: <WRAP prewrap>
/bin/sh ../../libtool --tag=CXX --mode=link mpicxx -Wl,--no-as-needed -g -O2 -pg -pg -dynamic -o Sherpa ../../*/*/*.o ../../*/*/*/*.o /home/projects/ATLASQ/tools/HepMC-2.06.08/src/*.o /home/projects/ATLASQ/generators/sherpa-02-01-00/sqlite-autoconf-3080200/install/lib/libsqlite3.a /soft/libraries/alcf/current/gcc/ZLIB/lib/libz.a -L/projects/ATLASQ/ol-mpi/lib -lopenloops -lcoli > libtool.log
</WRAP>
This will fail because the PDF libraries contain overloaded functions and cannot be all loaded together. Sherpa loads these dynamically so the sed
command below removes all the PDF object files.
<WRAP prewrap>
sed s/"libtool: link: "//g libtool.log | sed s/"..\/..\/PDF\/CT10\/CT10_Fortran_Interface.o"//g | sed s/"..\/..\/PDF\/CT10\/CT10Pdf.o "//g | sed s/"..\/..\/PDF\/CT10\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12Pdf.o "//g | sed s/"..\/..\/PDF\/CT12\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CTEQ\/CTEQ6_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CTEQ\/Cteq6Pdf-2008.o "//g | sed s/"..\/..\/PDF\/CTEQ\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/Electron\/PDF_Electron.o "//g | sed s/"..\/..\/PDF\/Electron\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/GRV\/GRVph_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/GRV\/grvphoton.o "//g | sed s/"..\/..\/PDF\/GRV\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2001lo.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2004qed.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst99.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST01LO.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST04QED.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST99.o "//g | sed s/"..\/..\/PDF\/MRST\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MSTW\/mstwpdf.o "//g | sed s/"..\/..\/PDF\/MSTW\/PDF_MSTW.o "//g | sed s/"..\/..\/PDF\/MSTW\/SVN_Info.o "//g > compile_Sherpa.sh sh compile_Sherpa.sh
</WRAP>
Now to run a test. <WRAP prewrap>
qsub -t 20 -n 1 --mode=c1 Sherpa -l run.codegen.log INIT_ONLY=1 qsub -t 20 -n 1 --mode=c4 Sherpa -l run.integration.log SQLITE_OPEN_FLAG=unix-none
</WRAP>
The SQLITE_OPEN_FLAG is explained here: https://sherpa.hepforge.org/trac/ticket/263?cversion=3&cnum_hist=2
<WRAP prewrap>
tar xzf SHERPA-MC-2.1.1.tar.gz cd SHERPA-MC-2.1.1 ./configure --enable-gzip --enable-openloops=/users/hpcusers/tools/OpenLoops --enable-hepmc2=/users/hpcusers/svn/tools/HepMC-2.06.08/local --enable-mpi --enable-static=yes --enable-shared=yes --prefix=$PWD/install --with-pic make V=1 -j 10 > make.log 2>&1 & make install
</WRAP> This will create the Sherpa executable but will have a dynamically linked executable. As seen here:
ldd SHERPA/Run/.libs/Sherpa linux-vdso.so.1 => (0x00007ffff4bff000) libSherpaMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaMain.so.0 (0x00007f83841ea000) libSherpaInitialization.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaInitialization.so.0 (0x00007f8383fbe000) libSherpaPerturbativePhysics.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaPerturbativePhysics.so.0 (0x00007f8383d62000) libSherpaSoftPhysics.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaSoftPhysics.so.0 (0x00007f8383b36000) libLundTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libLundTools.so.0 (0x00007f8383935000) libSherpaTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaTools.so.0 (0x00007f838369b000) libAmisic.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmisic.so.0 (0x00007f838348e000) libAmisicModel.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmisicModel.so.0 (0x00007f8383251000) libAmisicTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmisicTools.so.0 (0x00007f838303c000) libCSTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libCSTools.so.0 (0x00007f8382e30000) libCSCalculators.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libCSCalculators.so.0 (0x00007f8382c04000) libCSShowers.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libCSShowers.so.0 (0x00007f83829d2000) libCSMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libCSMain.so.0 (0x00007f83827af000) libAhadicMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAhadicMain.so.0 (0x00007f83825a6000) libAhadicTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAhadicTools.so.0 (0x00007f8382326000) libAhadicFormation.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAhadicFormation.so.0 (0x00007f8382114000) libAhadicDecays.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAhadicDecays.so.0 (0x00007f8381f10000) libShrimpsMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsMain.so.0 (0x00007f8381d01000) libShrimpsEvents.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsEvents.so.0 (0x00007f8381ac1000) libShrimpsBeamRemnants.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsBeamRemnants.so.0 (0x00007f8381894000) libShrimpsXsecs.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsXsecs.so.0 (0x00007f8381674000) libShrimpsEikonals.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsEikonals.so.0 (0x00007f838144c000) libShrimpsTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libShrimpsTools.so.0 (0x00007f838123d000) libBeam.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libBeam.so.0 (0x00007f838101b000) libComixAmplitude.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libComixAmplitude.so.0 (0x00007f8380dd3000) libComixPhasespace.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libComixPhasespace.so.0 (0x00007f8380b8b000) libComix.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libComix.so.0 (0x00007f8380952000) libComixCluster.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libComixCluster.so.0 (0x00007f8380738000) libAmegic.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmegic.so.0 (0x00007f83804cc000) libDipoleSubtraction.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libDipoleSubtraction.so.0 (0x00007f838024e000) libAmplitude.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmplitude.so.0 (0x00007f837ffc6000) libAmegicPSGen.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmegicPSGen.so.0 (0x00007f837fd1d000) libZfunctions.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libZfunctions.so.0 (0x00007f837fa76000) libString.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libString.so.0 (0x00007f837f83e000) libAmegicCluster.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libAmegicCluster.so.0 (0x00007f837f61f000) libModelMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libModelMain.so.0 (0x00007f837f38c000) libModelInteractions.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libModelInteractions.so.0 (0x00007f837efc4000) libPDF.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPDF.so.0 (0x00007f837eda6000) libRemnant.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libRemnant.so.0 (0x00007f837eb8e000) libMCatNLOTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMCatNLOTools.so.0 (0x00007f837e988000) libMCatNLOCalculators.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMCatNLOCalculators.so.0 (0x00007f837e771000) libMCatNLOShowers.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMCatNLOShowers.so.0 (0x00007f837e548000) libMCatNLOMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMCatNLOMain.so.0 (0x00007f837e329000) libPhasicChannels.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicChannels.so.0 (0x00007f837e05e000) libPhasicMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicMain.so.0 (0x00007f837de0b000) libPhasicProcess.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicProcess.so.0 (0x00007f837db7e000) libPhasicSelectors.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicSelectors.so.0 (0x00007f837d8e3000) libPhasicScales.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicScales.so.0 (0x00007f837d694000) libPhasicEnhance.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicEnhance.so.0 (0x00007f837d48a000) libPhasicDecays.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhasicDecays.so.0 (0x00007f837d271000) libMEToolsExplicit.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsExplicit.so.0 (0x00007f837d046000) libMEToolsCurrents.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsCurrents.so.0 (0x00007f837ce16000) libMEToolsVertices.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsVertices.so.0 (0x00007f837cbea000) libMEToolsColors.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsColors.so.0 (0x00007f837c9db000) libMEToolsSpinCorrelations.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsSpinCorrelations.so.0 (0x00007f837c7ce000) libMEToolsLoops.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsLoops.so.0 (0x00007f837c5ab000) libMEToolsMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libMEToolsMain.so.0 (0x00007f837c378000) libHadronsMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libHadronsMain.so.0 (0x00007f837c148000) libHadronsMEs.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libHadronsMEs.so.0 (0x00007f837bf0a000) libHadronsCurrents.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libHadronsCurrents.so.0 (0x00007f837bc7e000) libHadronsPSs.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libHadronsPSs.so.0 (0x00007f837ba68000) libPhotonsMain.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhotonsMain.so.0 (0x00007f837b85d000) libPhotonsTools.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhotonsTools.so.0 (0x00007f837b63b000) libPhotonsPhaseSpace.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhotonsPhaseSpace.so.0 (0x00007f837b430000) libPhotonsMEs.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libPhotonsMEs.so.0 (0x00007f837b1ee000) libExtraXS.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXS.so.0 (0x00007f837afdb000) libExtraXS2_2.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXS2_2.so.0 (0x00007f837ad95000) libExtraXS1_2.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXS1_2.so.0 (0x00007f837ab8f000) libExtraXS1_3.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXS1_3.so.0 (0x00007f837a984000) libExtraXSCluster.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXSCluster.so.0 (0x00007f837a781000) libExtraXSNLO.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libExtraXSNLO.so.0 (0x00007f837a55b000) libgfortran.so.3 => /usr/lib64/libgfortran.so.3 (0x00007f837a24e000) libdl.so.2 => /lib64/libdl.so.2 (0x00000031bde00000) libSherpaSingleEvents.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libSherpaSingleEvents.so.0 (0x00007f8379feb000) libToolsPhys.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libToolsPhys.so.0 (0x00007f8379d8f000) libToolsMath.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libToolsMath.so.0 (0x00007f8379ada000) libToolsOrg.so.0 => /users/hpcusers/svn/generators/sherpa/v211/test/SHERPA-MC-2.1.1/install/lib/SHERPA-MC/libToolsOrg.so.0 (0x00007f837983d000) libz.so.1 => /lib64/libz.so.1 (0x00000031bea00000) libsqlite3.so.0 => /usr/lib64/libsqlite3.so.0 (0x00000031cf600000) libmpi_cxx.so.1 => /usr/lib64/openmpi/lib/libmpi_cxx.so.1 (0x00007f8379622000) libmpi.so.1 => /usr/lib64/openmpi/lib/libmpi.so.1 (0x00000031bf600000) libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00000031c0e00000) libm.so.6 => /lib64/libm.so.6 (0x00000031be200000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00000031c0600000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00000031bda00000) libc.so.6 => /lib64/libc.so.6 (0x00000031bd600000) /lib64/ld-linux-x86-64.so.2 (0x00000031bd200000) libopen-rte.so.7 => /usr/lib64/openmpi/lib/libopen-rte.so.7 (0x00007f83793a6000) libopen-pal.so.6 => /usr/lib64/openmpi/lib/libopen-pal.so.6 (0x00000031bf200000) librt.so.1 => /lib64/librt.so.1 (0x00000031be600000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00000031c1a00000) libutil.so.1 => /lib64/libutil.so.1 (0x00000031cd600000) libltdl.so.7 => /usr/lib64/libltdl.so.7 (0x00000031c6200000)
To build a more statically linked executable do the following steps. <WRAP prewrap>
cd SHERPA/Run ../../libtool --tag=CXX --mode=link mpic++ -Wl,--no-as-needed -g -O2 -rdynamic -Wl,--no-as-needed -o Sherpa ../../*/*/*.o ../../*/*/*/*.o /users/hpcusers/svn/tools/HepMC-2.06.08/src/*.o -lgfortran /usr/lib64/libz.a -lsqlite3 > libtool.log sed s/"libtool: link: "//g libtool.log | sed s/"..\/..\/PDF\/CT10\/CT10_Fortran_Interface.o"//g | sed s/"..\/..\/PDF\/CT10\/CT10Pdf.o "//g | sed s/"..\/..\/PDF\/CT10\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CT12\/CT12Pdf.o "//g | sed s/"..\/..\/PDF\/CT12\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/CTEQ\/CTEQ6_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/CTEQ\/Cteq6Pdf-2008.o "//g | sed s/"..\/..\/PDF\/CTEQ\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/Electron\/PDF_Electron.o "//g | sed s/"..\/..\/PDF\/Electron\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/GRV\/GRVph_Fortran_Interface.o "//g | sed s/"..\/..\/PDF\/GRV\/grvphoton.o "//g | sed s/"..\/..\/PDF\/GRV\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2001lo.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst2004qed.o "//g | sed s/"..\/..\/PDF\/MRST\/mrst99.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST01LO.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST04QED.o "//g | sed s/"..\/..\/PDF\/MRST\/PDF_MRST99.o "//g | sed s/"..\/..\/PDF\/MRST\/SVN_Info.o "//g | sed s/"..\/..\/PDF\/MSTW\/mstwpdf.o "//g | sed s/"..\/..\/PDF\/MSTW\/PDF_MSTW.o "//g | sed s/"..\/..\/PDF\/MSTW\/SVN_Info.o "//g > compile_Sherpa.sh sh compile_Sherpa.sh cp Sherpa ../../install/bin/
</WRAP> Now you have:
ldd install/bin/Sherpa linux-vdso.so.1 => (0x00007fff8e5ff000) libgfortran.so.3 => /usr/lib64/libgfortran.so.3 (0x00007f63da4cc000) libsqlite3.so.0 => /usr/lib64/libsqlite3.so.0 (0x00000031cf600000) libmpi_cxx.so.1 => /usr/lib64/openmpi/lib/libmpi_cxx.so.1 (0x00007f63da2b1000) libmpi.so.1 => /usr/lib64/openmpi/lib/libmpi.so.1 (0x00000031bf600000) libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00000031c0e00000) libm.so.6 => /lib64/libm.so.6 (0x00000031be200000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00000031c0600000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00000031bda00000) libc.so.6 => /lib64/libc.so.6 (0x00000031bd600000) libdl.so.2 => /lib64/libdl.so.2 (0x00000031bde00000) libopen-rte.so.7 => /usr/lib64/openmpi/lib/libopen-rte.so.7 (0x00000031bea00000) libopen-pal.so.6 => /usr/lib64/openmpi/lib/libopen-pal.so.6 (0x00000031bf200000) librt.so.1 => /lib64/librt.so.1 (0x00000031be600000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00000031c1a00000) libutil.so.1 => /lib64/libutil.so.1 (0x00000031cd600000) libltdl.so.7 => /usr/lib64/libltdl.so.7 (0x00000031c6200000) /lib64/ld-linux-x86-64.so.2 (0x00000031bd200000)
Apply in this order:
Sometimes I have trouble applying these so just use a text editor to see what changes need to be applied.
It was found that certain Truth containers are not created in Athena Reco transforms if the HepMC::GenEvent::signal_process_id is not greater than zero. Therefore the following hack describes a way to introduce this.
I was using the following commands on ascinode.hep.anl.gov
with Athena setup with the environment asetup 17.2.12.7.10,MCProd,64,slc5
, though this should work for other releases as well. Then do the following from your Athena home directory where the InstallArea
will be created
cmt show versions PhysicsAnalysis/TruthParticleID/McParticleTools
Which ever version is shown for your relase do the following:
cmt co McParticleTools-00-19-00 PhysicsAnalysis/TruthParticleID/McParticleTools cd McParticleTools-00-19-00 PhysicsAnalysis/TruthParticleID/McParticleTools/src/
Edit the file named HepMcReaderTool.cxx
StatusCode HepMcReaderTool::read( HepMC::GenEvent* evt ) { m_ioFrontend->fill_next_event(evt); ////////// BEGIN NEW PARTS /////////////////// // required to be non-zero for TruthParticleContainer creation evt->set_signal_process_id(1); // taken from Generators/Sherpa_i/trunk/src/Sherpa_i.cxx:115 // ATLAS renormalizes the output Sherpa event weights if (evt->weights().size()>2) { evt->weights()[0]/=evt->weights()[2]; while (evt->weights().size()>1) evt->weights().pop_back(); } // Sherpa uses GeV, ATLAS uses MeV so convert all the momenta and energies. for (HepMC::GenEvent::particle_iterator p = evt->particles_begin(); p != evt->particles_end(); ++p) { // ATH_MSG_DEBUG("PDG, BAR " << (*p)->pdg_id() << " " << (*p)->barcode()); const HepMC::FourVector fv((*p)->momentum().px() * 1000, (*p)->momentum().py() * 1000, (*p)->momentum().pz() * 1000, (*p)->momentum().e() * 1000); (*p)->set_momentum(fv); (*p)->set_generated_mass(1000 * (*p)->generated_mass()); } ////////// END NEW PARTS /////////////////// return StatusCode::SUCCESS; }
Then run:
cd ../cmt gmake gmake install
You should now have this installed in your InstallArea
directory.
On Edison@NERSC:
module unload altd module unload darshan module unload PrgEnv-intel module load PrgEnv-gnu module unload cray-shmem module load scons module load mercurial module load cmake module load boost module load gsl ./scons -j 10 ./scons auto=all/ -j 15
Setup:
soft add +gcc-4.8.1
export PATH=/cvmfs/atlas.cern.ch/repo/sw/atlas-gcc/462/x86_64/slc6/x86_64-slc6-gcc46-opt/bin:$PATH
export LD_LIBRARY_PATH=/cvmfs/atlas.cern.ch/repo/sw/atlas-gcc/462/x86_64/slc6/x86_64-slc6-gcc46-opt/lib:$LD_LIBRARY_PATH
svn checkout http://openloops.hepforge.org/svn/OpenLoops/branches/public ./OpenLoops
cd OpenLoops ./scons auto=all/
This downloads all the process libraries and takes some time. List of libraries..
[OpenLoops] shared_libraries=0
