itk:extracting_channels_from_root_files
Extracting channels from ROOT files
Overview: This script (testanalysis.py) allows the user to print a list of problematic channels after running a test. The user inputs the ROOT file from the test, the specific histogram they would like to analyze, and must input the maximum number of hits possible in the channels.
Instructions:
- Download the package using the command
wget https://atlaswww.hep.anl.gov/asc/wikidoc/lib/exe/fetch.php?media=itk:testanalysis.py -O TestAnalysis.py
- Once you have the package, make sure that you have already installed ROOT or can open the ROOT file from your test.
- Open the script
vim (or emacs/whatever text editor you use) TestAnalysis.py
. - Input your ROOT file that contains the histogram from the test, the name of the histogram, and the maximum number of hits possible in all of the channels.
- Save script.
- Run script using
python TestAnalysis.py
- The information will be printed to the command line.
Script:
#This script allows the user to see the specific ouput for specific pixels on different electronic tests from ROOT import * #The user must input the root file, histogram, and the maximum number for bin content fileName = "~/calibData/TEST_NAME_0000RUN#/histos.root" #For example: an analog test with run number 11 ~/calibData/ANALOG_TEST_000011/histos.root. histogramName = "Mod_94220425_Occupancy_Point_000" #This is the corresponding histogram name for the analog test. maxValBin = 50 #This is the corresponding maximum hits for the analog test. #Do not modify the rest of the code, it should work given what the user has place above. test = TFile.Open(fileName) h = test.Get(histogramName) h.Draw("colz") for i in range(1, h.GetNbinsX()): for j in range(1, h.GetNbinsY()): binContent = h.GetBinContent(i, j) if binContent < maxValBin: print "*****************************" print "Pixel column (x): ", i print "Pixel row (y): ", j print "Number of hits: ", binContent print "*****************************"
itk/extracting_channels_from_root_files.1473968852.txt.gz · Last modified: 2016/09/15 19:47 by asc
