Setting Up RCE Pixel Application
Following the setup instructions here. Be sure to extract and install everything in exactly the same directories as listed below, because some scripts use hard-coded paths!
The pixel application has two parts - calibserver, which runs on the HSIO-2, and calibGui, which is run locally and used to interface with calibserver.
You don't need to edit /etc/hosts if your /etc/dhcp/dhcpd.conf file is set correctly. This automatically assigns IP addresses to external devices based on their MAC addresses. You can look at the leases created by DHCP in /var/lib/dhcpd/dhcpd.leases. This will tell you the IP address of the HSIO-2 board. You should be able to log on to the board using
ssh root@<IP>
If you get an error “No route to host”, this means you're using the wrong IP address.
Execute all the commands in this section as superuser:
yum install cmake libXpm libX11 libXext libSM libICE python-devel rpm-devel mkdir -p /sw/atlas chmod a+w /sw/atlas cd /sw/atlas git clone https://:@gitlab.cern.ch:8443/rce/ayum.git cd /sw/atlas/ayum ./configure.ayum
Enter the following information:
AYUM package location: /sw/atlas/ayum AYUM software installation location: /sw/atlas AYUM RPM database location: [/sw/atlas/.rpmdb] AYUM cache location: [/sw/atlas/.yumcache]
Keep executing commands:
cd /sw/atlas/ayum/src/rpmext make clean make cd ~/ayum ./ayum install -y LCG_81b_gcc_4.9.3_x86_64_slc6 gcc_4.9.3_x86_64-slc6 LCG_81b_ROOT_6.04.12_x86_64_slc6_gcc49_opt Boost_1.59.0_python2.7_armv7l_archlinux_gcc52_opt_lcgcmt81b_armv7l_archlinux_gcc52_opt cd ~ git clone https://:@gitlab.cern.ch:8443/rce/pixelrce.git ln -s ~/pixelrce ~/daq cd ~/daq/rce
Now you'll want to edit ./scripts/setup-gen3.sh. Add the following line before “source $LCG_INST_PATH/sw/lcg/contrib/gcc/4.9.3/x86_64-slc6/setup.sh”: “source $LCG_INST_PATH/sw/lcg/ROOT/6.04.12-c016e/x86_64-slc6-gcc49-opt/bin/thisroot.sh”.
source ./scripts/setup-gen3.sh
git checkout -b V1.1.0
cd ~/daq/rce/build.slc6-rcf; make
cd ~/daq/rce/build.arm-rcf; make
cd ~/daq/rce/
rsync -e 'ssh -l root' -rlptDv /sw/atlas/sw/lcg/LCG_81b/Boost/1.59.0_python2.7/armv7l-archlinux-gcc52-opt/lib 192.168.3.3:/root/pixelrce/
rsync -rlptDv -e 'ssh -l root' build.arm-rcf/{bin,lib} 192.168.3.3:/root/pixelrce
You can ssh into the HSIO-2 to run calibserver. This is not necessary unless you want to see real-time outputs from the server.
ssh [email protected] export PATH=/root/pixelrce/bin:$PATH; export LD_LIBRARY_PATH=/root/pixelrce/lib:$LD_LIBRARY_PATH calibserver
In another window, run calibGui on the local computer.
cd ~/daq/rce source scripts/setup-gen3.sh calibGui
Use Inlink X+1, Outlink X+1, where the module is plugged into port AX. Use Rce 0.
