itk:sim
ITK simulation
This wiki describes the simulation work at ANL focused on single-particle samples (with and without 140 and 200 pileup), and a future work on validation of the the proposed pixel geometry. The single particle samples created at ANL are discussed in Upgrade Simulation Inner Tracker wiki. The ongoing discussion of how to perform the full simulations can be found in ATLPHYSVAL-385. The following geometry is considered:
- ExtBrl4 is the extended Barrel layout with Eta up to 4.0
- ExtBrl32 is extended Barrel with Eta up to 3.2
- IExtBrl4 is the inclined layout.
- InclBrl4 is the fully-inclined layout.
Here are a few results obtained using the single-particle samples for the Extended Barrel 4 geometry. They are based on the 1 GeV single particle samples created at ANL and posted on Single particle samples wiki.
— Sergei Chekanov 2016/02/11 16:37
itk/sim.txt · Last modified: 2016/02/11 22:58 by asc
