itk:sim
ITK simulation
This wiki describes the simulation work focused on single-particle samples (with and without pileup) and a work on validation of the geometry. The single particle samples created at ANL are discussed here https://twiki.cern.ch/twiki/bin/viewauth/Atlas/UpgradeSimulationInnerTracker The ongoing discussion of how to do full simulations can be found in https://its.cern.ch/jira/browse/ATLPHYSVAL-385.
Here are a few results obtained using the single-particle samples for the Extended Barrel 4 geometry. They are based on 1 GeV single particle sample created at ANL https://twiki.cern.ch/twiki/bin/viewauth/Atlas/UpgradeSimulationInnerTracker#EVNT_Single_particle_samples
itk/sim.1455229900.txt.gz · Last modified: 2016/02/11 22:31 by asc
